Advanced Engineering Tech For the more hardcore LS1TECH residents
Internal engine stresses
Old Jun 1, 2017 | 03:57 AM
  #41
Dian's Avatar
go and limit the travel of the wastegate. no controller needed.
Old Jun 1, 2017 | 10:23 AM
  #42
pantera_efi's Avatar
Default Turbosupercharger
Hi Dian, I USE a controller to operate my turbosupercharger.
I use NO Waste Gate OR Exhaust.
Lance
Old Jun 1, 2017 | 10:44 PM
  #43
Dian's Avatar
i was actually referring to the original question. there are two ways to make a turbo act as a centri without complicated controlls. using a big turbo (mentioned earlier) and using "boost creep".
Old Jun 4, 2017 | 09:53 AM
  #44
Default VNT Turbos
Hi Dian, I also use a VNT turbo from a Ford Truck and install a larger compressor wheel/cover/seal plate for some applications.
There are more than two ways to to operate a turbocompressor.
1. Electrical operation as used in F-1
2. Hydraulic operation as used by BV on ships.
3. Self Powered operation used on WW-II fighters
NOW for JoeNova, YES a have made a LS-400 Diesel with four valve heads.
This was for the Battle Field.
The head was made by Russ Arao.
I fitted my ECU-882C with a DDI power board.
Lance
