4th gen aerodynamics
also anyone mention putting plexiglass on the spoiler to the hatch to cover the gap so no air goes under the spoiler? (trans am)
any how-to on a rear belly pan? sheet aluminum and rivets or self tapper?
still interested in improving 4th aero. do the wheel well gurneys actually help?
MAXX2 Racing 99 Formula
https://www.facebook.com/groups/408137802673551/
I thought about goin there.....one could for sure. What you run into is the bottom of the k is lower than the nose of the car. You want some rake in your pan from front to rear or you will get lift......you don't want that. So by goin all the way to the k it creates a dam for the air at the k. Because your panel will be above the bottom of the k.
I may try a panel goin from the rad support to the k after i get my tube k. Also realistically there is a point of diminishing returns here.
At 5ft span:
2" rise = 1.9*
4" rise = 3.8*
6" rise = 5.7*
Wondering if one could attach to the k member then drop from the front of the pan using spacers and find a way to fill the gap between the bumper and pan at the front to make the pan level if anything.
BUT, if one was able to quantify the possible lift you get from an upward angled front pan and compare that to the down force you might get from going to a ducted radiator through the hood....maybe they equal out? Maybe not? Only NASA will know! I kidd I kidd. This is also assuming upwards of 80+mph where any of this may take effect.
I have some rake in mine. I dont remember exhactly how much. Not alot because i wasn't looking for downforce or i woulda put tunnels in it. Just enough to keep it from packing.
I used the rk sport front lip on mine to get the front body low enough o mount the pan to. If not it would have been goin downhill to the rad support instead of slightly uphill......that woulda been no good.
I tell ya. From the nose to the k is a pretty damn big span. Overhang on these cars are huge compared to newer cars.
Of course as speeds increase. The effectiveness go's up. Autocrossing wouldn't see much benefits unless it was very large wings, splitters, gurney lips, diveplanes at the typical autox speeds. But that doesn't mean it's not there.
I'm lowered on coilers so if needed I CAN adjust ride height if the nose gets too low. Still trying to keep this DD friendly.
Something like what Jon did here may be needed:
http://www.jonaadland.com/Z28/Mods/S.../Splitter.html
