500whp 5.3 N/A possible?
it's tricky on speccing LLSR. Basically, i look a the hydraulic cam i'd suggest and add 5 degrees. At least for a starting point. Guys like Steve, Kip, and Martin are better at it than me. So, i threw 242/250 out there. might even want a bit more, but I don't think you'll want too much more than that.
I certainly felt like the the LLSR was a big kick in the pants on power over the hydraulic. Definitely more responsive to the throttle. I went from 496 through a stock-geared ten bolt to 519 through a 4.11 geared 9". So, it's at least 25 HP, plus overcoming additional drivetrain mass.
Cost of entry isn't too bad. The lifters aren't that much different from morel drop-in hydraulic lifters on price. Actually, cheaper than some of the high end hydraulic lifters. And you can do it without the adjustable rockers. Don't get me wrong, Jezels and HS are great rockers, but you can do it with YT non-adjustables as long as your cam base circles are about the same. You just need a set of machine shims to set the pedestal height to get to zero lash. you also need to match your pushrod lengths almost perfectly so that your rockers pairs are level - intake and exhaust. That's the short version of how I did mine. It was right near 150K when I did the swap, and it's 165K now, so it's reliable so far. Last i knew, Kip had LLSR on his DD Camaro, and was at 24K miles - at least a year ago, if not two years ago.
So, it's not the $3K+ upgrade it used to be by any stretch, and it's very durable. In a way, it might be better than adjustable rockers. I mean, is a rocker adjuster more likely to come lose or is a machine shim more likely to change it's thickness?
Thanks For the info.
Still. If a 5.3 was making an honest 500whp I would like to see what it took.
Pantera efi made a comment about itb's
As you can see on my dyno sheet "lets not get in a discussion on dyno's"
I have a double torque peak.
The peak doesnt coincide with any timing or fuel discrepancies. So I am thinking it must be something else.
Im wondering if it has something to do with intake runner length vs camshaft torque peak
I am trying to decide if i should build a more appropriate sheet metal intake or if i should build an itb setup.
So, I guess, yes, I'd say either a sheet metal intake or ITB. I seriously considered ITB, just because it's an infinitely large plenum. Where there is a benefit to a sheet metal intake is a CAI that goes down to the nose of the car like CHRS1313 built could pressurize a sheet metal intake, but not an ITB, unless the ITB was then encased in a larger plenum. A true ram air that works quite well, actually...
but if you're asking between the two, which to choose? I'd have to punt.
There ARE many applications where this is good, not for HP "peaks" but needed to win races by having a WIDE torque range engine.
I was the first to assembly a LS-1 with stock bore/stroke (N/A) and bench over 600 HP. (Chevy Hi-Perf Article)
I used AFR cylinder heads I bought from Guy Trip when he worked for AFR.
I state an engine with "flat tops", my ITB's, a street-able camshaft (246/252 .600"/.561" 116C/L (solid rollers), CHE's, no special "exotic" items.
My EAP (engine dyno inside a PC) method for your needed 500 Wheel (620HP bench) required a much larger camshaft. (not street friendly)
So I ask AGAIN, could you state your C.R., port flow numbers, intake style, exhaust pipe length/tube bore, lifter solid/hyd, etc. ?
AS for Valve Lash, I have used Lash Caps when stock rockers (with CHE's) are required.
If you want to try my 65mm ITB's I will make you a "best price" dealer.
Lance
There is a section that discusses the hp limiting factor of Valve size in an LS2. Basically it seems with top notch 799/243 ported cylinder heads and a 2 inch valve 620 flywheel hp is about the limit.
http://www.hotrod.com/articles/ctrp-0704-nascar-new-motor/
The 5.3 engine with a stock bore of 3.780 is limited to about a 2.00 inch intake valve with a factory casting cylinder head like the 243/799. Since the Wegner heads are more capable than the "706" 5.3 castings. If 5.3 heads are 243/799 castings like the Wegner's I think they will max out at 620 hp best case after porting and valve job when limited to a 2 inch valve.
The NASCAR Spec LS2 in the article makes about with 620 flywheel hp. With the drive train mentioned above, like Lance/Pantera EFI mentioned the DL loss will be around 18% to 22% to the wheels. This would yield around ~495 whp plus or minus 10whp with a 620 flywheel engine. The 5.3 being bore limited would probably make a bit less hp than Nascar spec vacuum pump LS2 mentioned in the article did.
To me this makes the argument that an aftermarket head with a different valve angle is needed for this project. Heads with 11-13 degreed might allow for a bigger valve..maybe a 2.02 or better. In any case every hp will matter to reach the goal.
The heads Darth suggested are definitely worth considering. Trick Flow has offered a head specifically for the 5.3 that might be worth checking out too. Mast probably has some to consider as well.
Does the current 5.3 in the Focus have a crank scraper?
BTW - cool car and nice swap! A++
FWIW - I think the ITB manifold is almost certainly the best way to wring all the NA potential out of the cylinder heads.
http://http://www.hotrod.com/article...car-new-motor/
I cant get the link to work.
Also no it does not have a crank scraper
I have seen contradictory tests with 1 3/4 and 1 7/8 comparisons.
Thoughts?
Thoughts?
I think this one should work.
Definitely 1 7/8 primary headers.
