Advanced Engineering Tech For the more hardcore LS1TECH residents
Piston Pin Offset Direction
Old Dec 10, 2017 | 11:03 AM
pantera_efi's Avatar
Default Piston Pin Offset Direction
Hi ALL, there is little "tech" here about piston pin offset.
MOST ALL those piston manufacturing companies put the Pin "on center".
This is NOT the best case for MANY applications.
So I ASK, what would be the offset direction for a S/C engine ?
Lanec
Old Dec 11, 2017 | 02:25 PM
JoeNova's Avatar
Restricted User
Are you talking side to side offset? Won't you end up with horrible piston rock if you offset the pin?
Old Dec 11, 2017 | 07:47 PM
Actually Joe, all oem and most aftermarket LS pistons have offset pins. There is a performance advantage in doing this, as well as helping to quiet piston slap.
Lance is asking which direction (12oclock vs. 6oclock) to offset the pin for a s/c engine would be better.
Old Dec 12, 2017 | 07:26 AM
JoeNova's Avatar
Restricted User
Are we talking compression height?
Old Dec 13, 2017 | 11:52 AM
Default Pin Offset = Boost Safety
Hi Joe, I am speaking about HOW FAST the piston moves AWAY from the cylinder head.
Lance
Old Dec 31, 2017 | 05:04 AM
Dian's Avatar
whats the answer?
Old Dec 31, 2017 | 09:33 AM
We'll find out, when some one has it! lol
Old Dec 31, 2017 | 12:22 PM
Hi Dain, thank you for your interest.
The question was directed to HELP those who want more/less BMEP related to crankshaft position.
The question "how much compression" is NOT VERSED well by those ask !
Examples :
The LS 4.8/5.3 engine needs a compression increase in many cases, thus the offset is opposite OEM direction.
The LS-427 is common with a 12:1 compression and Flat Top Piston, thus the offset as in the GM OEM direction.
The difference is about .5 C.R. change difference in Knock Resistance.
Lance
Old May 29, 2018 | 09:25 PM
garygnu's Avatar
would having the piston pin set toward the the outside of the piston ,put more frictional drag on the piston ,but also have less dwell time at TDC ? and quicker piston acceleration speed to and from TDC ?
Old May 30, 2018 | 01:04 PM
Default Turbo Engine Pin Offset.
Hi Gary, YOU are correct, an offset pin as is done by OEM's (LH) ALLOWS the piston to move FASTER AWAY from TDC , VERY GOOD for a Turbo Application !
ALSO much easier on the SKIRT/Cylinder Walls.
Lance
Old Jul 7, 2018 | 05:44 PM
stevieturbo's Avatar
Surely all pistons are offset these days ?
I know any I've used in recent years have been, Wiseco, Diamond, JE
