Latest and Greatest Proper Engine Break in Procedure
Question - does the Y block make a difference here? Overfilling the SBC I could see it being an issue. But the Y block - does that added clearance eliminate much of the reason behind the overfill = bad consensus?
Should low tension rings have a diff procedure vs rings of old?
Have major advances in lubricants changed things? I remember an oil cap saying "do not use whale blubber". Compare that to castrol edge for example.
Have advanced in marching (tighter clearances) changed the procedure or is that more where lubricants come in?
I don't thing there's anything wrong with how Darth broke it in, it just makes things interesting talking about which way is best. There's also viewpoints like this dude:
http://www.mototuneusa.com/break_in_secrets.htm
I will add, in the 1970's we used a different ring pack AND a different cylinder wall honing procedures. (100 grit stones)
Today most common, with steel rings, is 280 Grit with 400 Grit as the final pass.
THUS to be fair, provide good tech, we should specify a cylinder hone method.
This too MUST match the fitted ring pack for proper tech.
SO I ASK, "Post your cylinder wall hone method, stone grits, block temps ?
Then state best run in method for for each style of rings/wall prep
Lance
As to the link, I do subscribe to the "Load it up early" method, but not immediately. I like to at least get a couple of heat cycles in to make sure the bearings and oil surfaces are all good and lubed up first. Then, I do 20-50 mph in second like I posted and coast back down in gear. Not sure I agree with why the author says load it up. I always felt it had more to do with just getting them properly seated
I'd also be curious what someone like Thompson Motorsports thinks since they build engines as a business.
Curious why the oems don't usually subscribe to this load early method.
AS WE KNOW, cold oil flow is SLOW AND hot oil flow is faster.
Oil flow IS what removes heat NOT the Oil Temperature difference.
THUS cold oil on cylinder walls will remove less heat between the rings/cylinder wall.
I have fit Cartridge Heaters into LS Oil pans to heat the oil before startup.
I sell this item for $60.00.
Lance
I think its something that doesn't make that much of a difference in the long run as long as you dont do something grossly incorrect.
modern materials science and manufacturing negates the need to do the break in rain dance of the 20th century.
Most high performance powersports toys these days use a plated cylinder (nikasil) which is harder than the hubs of hell. So you really only get a short chance to break the rings in. On sleds (2 stroke, 800cc, 155-160 hp) There have been several instrumented dyno test done, that show an engine broken in hard, and soon makes more power than the same one given a gentile break in. (~5 hp or more)
and My Engine Builder Dustin Lee used a very
similar procedure for my 396"
Its all about the ring seal,and it happens very
quick...or should.
I am a strong believer in running an LS at 190 degrees or less. Kept some rather high hp pump gas street cars alive that way even though people claim they're fine at 210.
I also am a pretty strong believer in the Shell conventional Rotella. I don't get into the synthetic stuff and believe in more frequent oil changes in general. A secondary reason for changing the oil other than the oil breaking over time, is that it also cleans and removes junk from the motor. When you change it more frequently you remove debris and impurities more frequently.
Also becoming a big believer in running more than 5.5 quarts and leaning more towards 6.5 or 7. Seeing alot of high hp street guys logging oil pressure with accurate resolution now and hard qcceleration is dropping the fuel pressure significantly even if only momentarily.
