Cryogenics and micropolishing rotating parts
I am especially interested in engine and driveline parts such as crank, Ross, pistons, valves, transmission gears, rear end differential and gears... basically any part that causes friction.
I'm interested in making my car as efficient as possible at the track and this is part of the process.
I'll be running a LLSR cam and turning it pretty good.
The car will still be a street car, but leans heavy towards a drag car.
I'm looking at maximizing it's potential, because I'm nerdy like that.
There are plenty of low or no cost ways to make your car faster. Power to weight ratio comes to mind, Lighten the car as much as possible, Run all synthetic lubes. Cold air intake and so on.
Here is a company with a pretty good rep. See their price list.
http://www.performancemetal.net/
And one thing to consider -- say you are already max effort. Heads, cam, intake, port work, vacuum pump, throw the kitchen sink in there. Where are you going to make more power? If you are running 243 heads and a 227 cam, yeah don't bother. Agreed. You could spray it sure. And really that's about all that is left. Boost would be a whole new build or at least heads, and certainly not cheaper.
The pro mods and pro stock guys aren't doing it for no reason.
The reason I don't see it being worth it on hobby grade street/strip car with small exceptions for strength is the cost versus real world performance gains. If you went front to back treating all rotating parts your only going to see a small performance gain and that means running low viscosity lubes that aren't all that street friendly. If you have a weak link where durability is an issue like the trans then it's a good idea but when it comes to the engine and rearend you're not likely to see much in the way of a performance gain, Durability shouldn't be an issue if you bought good parts to begin with.
There are better ways to spend that money that will lower your times if you're on a budget that will actually see bigger gains per dollar and last much longer than the than those treatments. Shed weight where you can and concentrate on any rotating parts like wheels and rotors and possibly the driveshaft. Fill it full of synthetic fluids. Remove all the heat/ ac related parts from under the hood and dash. Lighter is not only faster it's easier on the driveline.
I raced Microsprints for a few years, We had a minimum weight and engine size limit so we concentrated on rotating mass, I spent a decent amount of my budget on the engine removing the charging system, Remove gears not needed from the trans, Light weight flywheel, Removing the charging system to save weight and drag on the engine. Ceramic bearings anywhere they could be used. In the end it might have shaved a couple tenths off a 12 second lap. Two tenths doesn't sound like a lot but when you run 15-20 laps it can mean the difference between running up front and being last.
If there were no weight or engine rules I could have went a bigger engine and shed weight and probably knocked more than a second or two off my lap times.
I've heat treated axles before in a 600 degree oven using a 600/400/200 method and the axles came out slightly blue in color and I never managed to break one.
I've also seen what happens to driveshafts when torsion tests are done on them and they test one that's been frozen with liquid nitrogen. It shatters well below the normal failure point.
Take that with a grain of salt, as I haven't seen the test done with one after it was frozen and returned to operating temps.
Drag race/LSR motorcycle engines have few build constraints but each of those builds make use of additional lubricity treatments. For the reasons stated above I never tick the surface hardening box. On really potent drag race engines(big bore w/N2O, turbo, or really crazy NA) we install billet transmission shafts..not simply outputs, but these are typically the first to shear. The maker of the billet stuff has the usual suspects in stock and all parts are pre-micropolished.
One more bit of drivel. On a certain build the camshafts are extremely expensive with one vendor getting 2,500USD for a pair. We have our own grinds and the cams are gun drilled as well as ISF'd. We have never even seen anything like camshaft wear on these jewel-like pieces. I am uncertain as to whether or not this is a confirmation of surface treating the camshafts, valve springs and followers, but the engines are turned up to 15,000 RPM and the first inspection interval is 30 hours of track time. That's many years(decades?) of drag strip thrashing. I have yet to see even one broken valve spring in the ~30 engines of this type involved in roadracing/LSR events/drag racing.
I do car stuff too, but this sort of thing would only seem of benefit where every piece of low-hanging fruit has been picked. I have used other coatings and treatments in car stuff, but only if it's 'free' such as Wiseco's ArmorGlide coating. Nitriding on a racing crankshaft should be a given. I'm mostly evidence driven. Via no pre-conceived notions I try and avoid confirmation bias; but in motorsports there is a lot of BS passed around as fact. I'm not a Missourian, but 'Show Me.'
*If I have seen it come through, I already gave it the special shiny treatment.
