Advanced Engineering Tech For the more hardcore LS1TECH residents
HP gains from blueprinting alone.
Old Nov 17, 2005 | 12:05 PM
LSwonderfull's Avatar
Originally Posted by patSS/00
Just wondering, what are anti-detonation grooves? And, when did they start having them? Thanks.
They are a channel cast or machined into area between top ring groove and second groove. The way i understand them is its there to act as a resovoir of pressurized gasses to assist in better compression ring seal. This is similar to running larger 2nd ring end gaps. This accumulator function helps keep rings stuck to ring land as piston direction changes and as pressure differentials occur. Hope this helps. Can anyone add to this?
