HP gains from blueprinting alone.
To blueprint a block you have to start by locating the transmission dowels to the main housing and cam bore.
Once these measurments are correct (corrected) you then check the head dowel locations to the cam and main housing locations and make any changes needed.
Once this is done you can measure the cylinder bore locations and correct them as needed.
Once this is done you can align hone the mains, torque plate hone the cylinders and then surface the decks 90 degrees to the main housing.
I think most shop assume most of these locations are correct to begin with and just align hone the mains, torque plate hone the cylinders, surface the decks and call it a blueprinted block.
I personally do it so I know my motors will live under the harsh conditions found at the race track.
As well it's a lot of work for 20HP, you can easily gain 3 times that by working on your heads and cam. Another reason most shops don't bother with it.
Next time you go to buy or get your block blueprinted ask the shop your going to how they do it...
To the above list, you can add things like indexing the crank throws along with checking stroke, chamfering oil holes as well as deburring all parts and chamfering especially threaded holes in an aluminum block, to eliminate thread pulling, con rod work, port matching, checking lifter location and the list goes on.
Experienced builders know what problems each type of block is likely to have.
If the builder and/or machinery isn't up to snuff, the engine can turn out worse than before it was touched.
There are some decent books out there decribing the process, but the only way to know for sure is if you have the gauges, etc. to check the work.
When I used to build a lot of engines in the 70's, the shops that I used knew that I was going to check everything. On first visits to a machine shop, I would bring micrometers and dial bore gauges, etc and ask them to measure some parts (like cranks,etc) that I had already measured. I made sure that we were on the same page, so if I asked for something to be a certain size, they knew that it better be right.
Even so, on many occasions, I had to go back with my gauges to discuss a problem or prove a point. (Best to use good diplomacy)
Anyone can make a mistake, so if you can't check it yourself, then it is best to go with a shop that has a very good reputation with the race crowd.
Some shops are just NOT capable of doing high quality work , period.
On a high powered street application, there is no need to go crazy on this.
There is a lot that you can do to prep a block and other parts that can help ensure that you have a quality end product, but most of it is just common machining and finishing practices and will not net any extra power. It could however help avoid serious problems down the road.
Here's my question. Nobody in Wichita, KS has a torque plate for a this block, so I'm considering getting it honed without a torque plate once it's bored. I am going to have the main caps surfaced by about .001" and align honed as two of my mains are about .0005" oversize and the center main is .001" oversize. I'm also going to have it decked for a quench of .040". I'd prefer to use a torque plate, but I don't think that it's worth it for a single use in my application. What are your opinions?
Thanks,
Steve
Steve
Steve
the real questions stands- 0 or 100 hp, why WOULDN'T you use one?
The reason is that no one locally has a LSx series torque plate in town for bores exceeding about 3.95 inches. This would force me to buy a torque plate for a single use if I have it machined locally which I prefer to do.
Steve
