Dynamic Effective Compression Ratio
As for the add 15 to the .050 number? I dont exactly agree with that. My duration at .006 is 281 and at .050 its 230. For my cam I needed to add ~25. I would imagine there are even less agressive profiles out there that would need even more added to the .050 numbers.
As far as the .ooooooooooooo1 you also have to consider there is valve train deflection and other events which may not actually make the valve move at all off the seat until .006 or even higher so the advertised number of .006" is probably pretty accurate.
Yeah, I got this part. I believe the f-13 has an intake duration of 281 @ .006 and 230 @ .050. Thats 51 degrees. 51/2 = 25.5. I rounded down to 25. if 20 is quick, 15 is even quicker for a hyd cam.
As for the second part, thats what i figured. Just go by advertised closing @.006.
Oops, sorry, missed that. Yeah, 15 is pretty much unheard of in hydraulics and fast for solids. The TK stuff from comp is their fastest standard rocker ratio lobe and it takes 28 degrees to get from .006 to .050 on both sides, 14 on one side. My street solid roller takes 38 degrees to get from .006 to .050 on both sides and 19 on one.
If you are only talking a difference of one or two degrees I don't think it will influence the DCR that much anyway. Good luck
so if you have a weak ultra low lift cam and a huge restrictor, no air is going to make it in the cylinder. pressure is low, no boom.
Good tuning is an essential element to your scheme. Polish your combustion chamber, piston etc and use sodium exhuast valves. There are some good tricks to getting away with more ion. For some reason, good tuning is still a secret
I guess I woulnt mind dumping in a gallon of toluene if i really had to, but like you said, could always just pull timing.
F14= (232+15/2 + 112) - 180 = 55.5 Plug that in with stock LS1 specs and 62cc chambers and even a .052" gasket nets me 9.337DECR
What am I missing???
as for the second part- a smaller gap simply means your intake valve closed earlier. no more, no less. it just means the intake valve closes earlier in the compression stroke.
PS: It would take an IVC of 'only' ~ 102 ABDC to get an 8:1 DCR from a 16:1 SCR..
PPS: Maximum safe DCR really boosts torque in the low RPM range where a big cam is weak.
Results : It took down a Banshee with headers and pipes (360cc twin cyl, water cooled 2 stroke)
Ihave also done 2 stroke RC airplane engines with good results.
Moral of the story? It can be done, but atv and RC engiones are much cheaper to rebuild than LS1's, so tread softly..
