Benefits of a 32 valve heads
But slap 4 valve heads on it and see what happens. I'm not saying exotics are superior, I'm saying their engine design is. You can't beat the flow offered by 4 valve heads.
this is the main reason why big American V8 have never really made it in Eurpo. fuel in england at the moment is around £1 per ltr (about $1.8 per ltr). now if you want to talk abut fuel consumption lets talk about a nice 1.3ltr turbo diesel thats doing about 50mpg!
now if your talking about power!!!!
thanks Chris
http://www.coatesengine.com/csrv.html
how is that for a head??
He is also know for his exageration abillitys as well
I personally watched him dyno a VW 1835 he claimed made 250 hp + it was N/A btw
and the next day we heard it seize on the dyno from next door (we had a nice chuckle)
Essentially, a 10,000rpm pushrod would be far "peakier" than a 10,000rpm 4v--the Tymensky's old big bore 305CI/4v ran through the traps at 10,000rpm, made peak at 9200rpm, and idled at ~1400rpm.
We should all pray for a state of the art, large displacement & bore (which Modulars lack, limiting valve/seat size and ultimately limiting power) 4v V8 from GM. I'd be a convert for life.
Regarding Ford GT/GT500/R heads vs. LS7s...
On a 3.57" bore (.020" over 4.6 or 5.4) unported GT heads flow around 305-310cfm@.500" intake and 255-260cfm @ .500" exhaust. After porting they're around 350-370cfm @ .500"/290-310cfm. This is with tiny (relative to what they should be for motors of this displacement) 37/32mm valves. Just imagine what would happen with a 4"-4.125" bore.
As the guy above me stated in a nutshell, flow! Most foreign exotics utilize 4v heads. They get better gas mileage, make more power, have wide torque curves, yada yada yada. Yes they have the advantage of amazing EFI systems that have seperate real time fuel trims PER CYLINDER, but that is again better components. As for the 1/4mi, that's where it gets gray. You can run as fast as any human could ever want with 2 valves, this has been proven. But for a daily driven car, with say 600hp, the 4v heads will enable the engine to drive and act MUCH nicer. Lower idle, smoother running, quieter, etc.
As for the decent DOHC 32v engine, it will take time. Cadillac has got the best engine GM makes, which is of course the Northstar. (Slight bias there..) With some more displacement, that engine would be everything the 7.0l LS7 is and SO much more. Hell $2500 at CHRF will bring a N* on the verge of 1hp/l.
Also, let's not give all the credit to the "engine" design of the exotic, as vehicle weight (not necessarily total weight, but where the weight is positioned on the vehicle), suspension, TRANSMISSION GEARING.... all come into play as far as their unrivaled(?) performance.
I shouldn't say exotics like I do, more should say companies using advanced 4v design (Honda, Nissan, etc). The exotics just have the funding to take it one step further, not in specific output, but in total output.
When I was younger, an engine builder I knew said this: "If you want to know what's best, pull the fairings off a GSX-R once a year." I can't argue.
Weight
Size ( Dimensions )
Fuel Mileage
Power output
is it noisy or not?
Is it supportable ( IE you can get parts for it )
Who cares if it is a 4.5L motor with 4V per cyllinder DOHC making 375HP and 22 MPG on highway, taking up 10 cubic feet of space, that weights 620LB
or a 7.0L motor using pushrods, making 520hp and 28 MPG on highway, taking up 8 cubic feet of space, that weights 450LB?
you see what Im saying. Its about what goes in, what goes out and the weight.
