vic Jr versus Standard intake question....
since its a throttlebody, and the vacuum/airflow isnt metering your fueling, i donno.
personally, i wouldnt run it like that. id fabricate some kind of plenum to fit onto the manifold, smooth the edged for that transition into the manifold, and mount the throttlebody on the plenum.
also i really agree with SStrokerAce on the bolton expectations of some.. that manifold isnt meant to be bolted on. the VicJr for the SBC isnt meant to be bolted on.. the $90 VicJr clones you can get off ebay isnt even ment to be bolted on.. they're all cast with undersize ports so you can exactly match them.
the ONLY race oriented (aka not street) massproduced aftermarket manifold ive ever known to NOT need portwork is the LSx... and thats because its injection molded plastic ment to match factory ports that are much more accurate from motor to motor then the older motor designs out there...
Why would you recomend an elbow/TB over this type setup? Anyone running that in an N/A setup with results?
Wouldn't a longer runner (LS6) be more advantagous at a lower RPM, and a shorter runner(Vic Jr) more advantagous at a higher RPM?
I agree with the above posted about a 106lsa being old school lol. I don't think so you need to run the LSA to keep the valve events in line for the particular app. The tight LSA will come as a by-product of running the shorter runners.
If using this Intake on an FI application, does it look like it will work out better overall or is the LS6 a better choice? I'm building a 408 street/strip set-up and have been looking very heavily into this intake. The LSx isn't as good as the LS6 intake due to it's tendancy to leak some.
IMO it would look sick to have this functional engine plate out of aluminum directing fresh incoming air right down the throat of the TB.
How do you port match a victor Jr intake to heads on an LS1. It uses orings instead of a gasket so I cant gasket match it.
Whats the trick you smart guys use?
Should I just buy a piece of gasket material and cut out the ports on the heads? Or is there some other trick to this?
Also how much "smoothing" of the runners should someone do? Just knock off the cast bumps? Is there such a thing as "too smooth" on the intake runner?
Thanks
But as I mentioned before if a test is done the steps must be made to split the difference the intake can shift with the stock mounting hardware and the intake and head ports are on, but that's just me. lol
Chris I think your Motor is a minni ver of John's minus the blower. If that Vic. Jr had a burst pannel it would almost pass! LOL
You should see how this thing is comming along! It is a work of art, expecaily for one of those "old school cars"
Thanks
Anyway with the heads on or off?
Either the template method (Heads on) using thin carboard or poster board. With the heads off you can also remove the valves and bolt the intake to the heads and spray from the CC.
That would be how I would do it if I had too
Runner length and LSA don't correlate at all.
Bret
This forum is to speak to advanced tech. Thanks
Ricks results on my car speak for them selves. Out of box results between the Vic Jr and 90/90 with everything else being equal, both dyno tuned, the 90/90 out performs the Vic Jr/accufab setup in this scenario.
what I'm thinking myself is even if I do port the intake and swap the cam, it may only get me back to the same numbers I had with the 90/90 setup if I'm lucky. Maybe our mistake was trying to compare the manifolds. This is where I need to consider if it's worth it.
Dan
Bret
