vic Jr versus Standard intake question....
someone is going to have to explain to me how the exhaust valve effects the intake runner length.
i understand the runner length tuning for RPM, and the intake valve timing, the pulses and echo pulses from the valve slamming around... but how does the exhaust valve timing have any effect on it??
i could buy into the theory that the valve OVERLAP has an effect.. but the overlap isnt dependant upon LSA.. sure the LSA effects the overlap for any given set of lobes, but its not what actually sets the final overlap, its just a factor in that equation, and therefore isnt the variable to be looking at...
maybe im overlooking something simple. can anyone writeup a quick explanation for me?
Nope it's overlap.... the fact that it creates a lower pressure in the port at intake valve opening is the key.
Bret
I can see using the accufab set up on top of the intake not being quite as effective as using an intake elbow with a 90 TB giving more plenum area and more velocity...I could be full of sh** though...
Bret
my thought would be that you want the pressure in the port to be as high as possible inrelation to the pressure in the chamber/cyl so that the air wants to rush in harder.
following that train of thought in my head, i could somewhat imagine that fast moving gas (moving = high pressure) going out the exhaust valve could make the intake port have a lower pressure in relation.. and if both valves are open at the same time, that could have an effect...
am i thinking correctly? how do you use this to your advantage?
Bret
From what I have heard from others that tried this, they lost even mre power than the TB on top of the Vic Jr.
Rick
Rick
Why would you recomend an elbow/TB over this type setup? Anyone running that in an N/A setup with results?
Certainly if you look at a 346ci with a mid sized street cam like that, I would posit that you are not out of intake.
Now in the case of a a friend with a 4xxci SR engine that went over 148mph on motor, he runs a hogan sheetmetal that is practically a tunnel ram. And he's out of intake.
A 346ci with say a hydraulic 252/260 with 225 AFR's would need more than a LS6 intake, because it would be choked. Might see more value with the single plane stuff with the SR stuff revving 7200-8500 NA and with hydraulic 252/260//108 type stuff. I'm generalizing bigtime here but my point is that a big cam big head setup will need an intake that will work in higher rpms.
And you should not have to add major timing to the LS1, the heads are much better than SBC's which typically need a a lot more timing.
Rick
Hell i'm a little concerned about my choice of intakes now. But ole well we will see what happens, and maybe we can swap a Fast on there for comparison sake.
Rick
So your under the impression the 90 degree intake elbow with TB for a bigger (408) CI with good aftermarket heads/bigger camshaft and FI would loose more power than the TB's sitting directly on the top of the Vic Jr.?
That sucks!! Guess I'll find out and post results...I knew I should have waited until some testing was done on these.
What would be the reasoning behind the elbows not working as well??
Hopefully it wont be as bad as some suggest. We'll see shortly. Which one does everyone think will be less of an issue with air "restriction"?
Because of clearance issues most of the F-body guys that are running this set up are using the sheet metal intake elbow...
yes, it was a 346, a 230-234 cam. IT was a basic test to see if there was any difference for those seeking a different style manifold.
Rick
I've done some tests on the out of the box intake elbows like the Wilson 110° and it only hurt flow thru the intake and head by 3cfm. With some porting and a 1" spacer that is basically gone.
Bret
