vic Jr versus Standard intake question....
I would like to PM you other Vic jr guys with my new cam specs and get some input. If you dont mind that it is? BTW, The "awww" factor with this intake under your hood is priceless.
I'm all ears if you want to share. I'll probably give out ballpark specs on mine once we determine if it works...I will share this though....LSA is going to be less than or equal to 107
I *think* I picked up alot with a simple quick portmatch.
Each of my ports LITERALLY had about 1/8" all the way around on the intake that I had to grind off and blend up the throat. I also knocked off all the casting bumps anywhere the grinder could reach which was a whole lot.
I probably took a pound of aluminum out of the intake. No joke.
The good thing is they make nice thick flanges so you can take away a lot of material but still have a lot left. I cant stress enough how this is NOT an "out of the box" bolt on for max performance.
Bret
Bret
basically it's what I and a very good head porter feel needs to be done to these things to make them work in a drag race motor.... the other two smart asses here know what's going on.
Bret
Bret
.....but I could be way off!
Then again, the question is why would you want to do that?
Bret
.....the name says it all! All the extra airflow does'nt hurt either.
.....the name says it all! All the extra airflow does'nt hurt either.----
Im gonna say "surgery" involves a 4500 flange and injector angles. Maybe a few other little tricks that i dont know about.
Now when you have 2 shifts rather than 1, it can hurt you more. The elbow setups help the plenum area, and it's not like we are talking about a sheetmetal tunnel ram setup here so it's not huge.... Add on to that unless you are over 700hp your not going to see a gain to going with more throttle body than a 90mm can give you.
So you really think a Dom flange is worth it for that reason? I'll tell you it's some work to convert that over to that.
Bret
Bret
other thing I can think of is if you cut it up to really access the inside for port
work and then welded it together. I have this manifold but I didnt think it would be that hard to port with the short runners-I could be wrong.
I don't know if you race your car competitively but adding a Dom flange would make sense in that situation. Feel free to PM me, I can keep a secret
All hope for these may not be lost yet!
https://ls1tech.com/forums/showthrea...10#post4720110
Congrats Nosboy!
Bret
btw got pics hosted Malark.
Yeah it's a average build for me, just not average in the relative sense
Bret
