Piston speed, Displacment vs HP?
Whats the relationship between piston speed, HP and Displacment? Also when is piston speed too much?
I think Increase in Crank size would change the pistons speed while a bore increase shouldnt change anything right? Is there a formula we can use for calculating piston speed?
Average piston speed (often called Mean piston speed) is calculated with a simple formula: Bore has nothing to do with PS calc. Obviously bore and stroke are both used to get the displacement you want.
PS (ft/min) = [stroke (inches) x rpm]/6
So the 7000 rpm max, 4 inch stroke LS7 has a PS of 4 x 7000/6 or 4666.7 ft/min. This is on the upper end of OEM piston speeds. A 3.26 stroke Nextel Cup engine has a PS of 5270 @ 9700 rpm. A F1 engine with a 1.565 stroke has a PS of 4956 ft/min. @ 19,000.
Maximum piston speed depends on stroke, rpm and to a fairly minor amount, on rod length, especially when you consider the fairly small range of rod lenghts available for a given stroke in a given block. Most comparisons use Mean (average) PS as calculated above.
In racing engnes where premature detonation is not a problem, most engines use the largest bores allowed which results in the shortest strokes and therefore lowest piston speeds for any given rpm. This keeps the friction losses down as well as keeping the loads on the rod down.
The 2005 F1 Mercedes 928 hp @ 18300-18500 rpm engine was rpm limited by rod strength according to Mario Illien, the designer. Interestingly, they were using slightly longer stroke and slightly smaller bores than the max bore allowed. Remember F1 engines run two races, practices, qualifying or about 850 miles in anger. A Cup engine probably runs around 600-700 miles in anger, but with half the rpm of a F1 (and a little more than twice the stroke) it only experiences about 1/2 of the piston gs.
Do a search for some lively discussion of the effects of PS. Not all contestants see eye-to-eye on things.
Remember that how I or anyone else explains things doesn't change how Mother Nature works. The fun part is figuring Her out.
My $.02
346 cid and 360 cid with a 3.622 Stroke has a 4225 PS at 7K RPM 25354
392-396 cid with a 3.900 Stroke has a 4550 PS at 7K RPM
383, 402, 408 and 427 cid with a 4.00 Stroke has a 4666 PS at 7K RPM.
438, 454 cid with a 4.100 Stroke has a 4783 PS at 7K RPM.
So assuming we got all of the setups down to 4225 PS which is the stock piston speed... Are they going to make the same power giving everything else the same?
For example a 3.900 Stroke at 6500 RPM would give 4225 PS
a 4.00 Stroke at 6335 RPM would give around 4225 PS
a 4.10 Stroke at 6185 RPM would give around 4225 PS.
The US model is running a 2.2L with a 3.57 Stroke at 8000 RPM which would yield a 4760 PS while the JDM model is running a 2.0 L with a 3.30 Stroke and push 9000 RPM which would put it around 4950 PS. Both engines makes the same HP even though the 2.0L engine is running the pistons around 2000 PS faster.
So can we conclude that running .1 L extra of displacment (Stroke Increase, not Bore) would equal 1000ft/min of extra PS to equal the same HP?
Can you now see why a Cup piston feels over 5000gs and an F1 piston over 10,000gs?
Look at how much torque each engine makes at power peak rpm.
Let's say they are 250 hp engines:
250 hp @ 8000 is 164 lb-ft.
250 hp @ 9000 is 146 lb-ft.
Now look at how much torque per liter @ power peak each engine has:
2.2L (164 lb-ft) has 74.5 lb-ft/L (~183 psi BMEP)
2.0L (146 lb-ft) has 73.0 lb-ft/L (~179 psi BMEP)
My conclusion is that the 2.2 engine does a better job of turning air & fuel into usable power than the 2.0L. IOW, each cc makes more torque at power peak rpm.
Would the engine(rods, pistons, crank, etc...) have the same amont of strain from running a 3.30 and 3.57 Stroke even though they are running the same PS. So it will be 8300 RPM for the 3.57 VS 9000 RPM for the 3.3 Stroke.
https://ls1tech.com/forums/showthrea...60#post4705260
l = rod length
r = half stroke
At 7000 RPM, w = 2.pi.RPM/60 = 733 rad/s
You can put in the formula for v without multiplying by w
(w just scales the velocity for different RPMs),
and plot for 0° to 360° or 0 to 2.pi radians.
360cid (4 Bore x 3.622 Crank)
383cid (3.9 Bore x 4.0 Crank)
392cid (4.0 Bore x 3.9 Crank)
402cid (4.0 Bore x 4.0 Crank)
408cid (4.030 Bore x 4.0 Crank)
427cid (4.125 Bore x 4.00 Storke)
454cid 4.200 Bore x 4.10 Stroke)
For each of these, what rod length and piston height combinations would be used...?
assuming stock rod length 6.125" and constant RPM
(rod length does not make much difference to piston velocity)...
Chart shows piston motion wrt to crank angle
L=rod length
R=half stroke
L=6.125 R=1.811
max dx/dA = +/-1.888976 in/rad at A = +/-75°
7000 RPM: max v = 1.888976 in/rad * 733 rad/s = 1385 in/s = 6923 ft/s
6000 RPM: max v = 1.888976 in/rad * 628 rad/s = 1186 in/s = 5931 ft/s
L=6.125 R=1.950
max dx/dA = +/-2.047242 in/rad at A = +/-74°
7000 RPM: max v = 2.047242 in/rad * 733 rad/s = 1501 in/s = 7503 ft/s
6000 RPM: max v = 2.047242 in/rad * 628 rad/s = 1286 in/s = 6428 ft/s
L=6.125 R=2.000
max dx/dA = +/-2.104814 in/rad at A = +/-73°
7000 RPM: max v = 2.104814 in/rad * 733 rad/s = 1543 in/s = 7714 ft/s
6000 RPM: max v = 2.104814 in/rad * 628 rad/s = 1322 in/s = 6609 ft/s
L=6.125 R=2.050
max dx/dA = +/-2.162914 in/rad at A = +/-73°
7000 RPM: max v = 2.162914 in/rad * 733 rad/s = 1585 in/s = 7927 ft/s
6000 RPM: max v = 2.162914 in/rad * 628 rad/s = 1358 in/s = 6792 ft/s
I used the following equations with generic graphing software:
position
= x
= r.cos(A) + sqrt(l² - r².sin²(A))
velocity
= v
= dx/dA.dA/dt
= ( -r.sin(A) - r².sin(A).cos(A)/sqrt(l² - r².sin²(A)) ).w
acceleration
= a
= d²x/dA².(dA/dt)²
= ( -r.cos(A) - r².(cos²(A) - sin²(A))/sqrt(l² - r².sin²(A)) - (r²)².sin²(A).cos²(A)/sqrt(l² - r².sin²(A))³ ).w²
w = dA/dt = 2.pi.RPM/60 = constant
where:
l = rod length (distance between piston pin and crank pin)
r = crank throw radius (distance between crank pin and crank center, half stroke)
A = crank throw angle (from cylinder bore centerline at TDC)
x = piston pin position (from crank center along cylinder bore centerline)
v = piston pin velocity (upward from crank center along cylinder bore centerline)
a = piston pin acceleration (upward from crank center along cylinder bore centerline)
w = crank angular velocity in rad/s
I can get them for u if i dig more. I hope someone who know it post the rods length for each one of those rod length.
I know that half stroke + rod length + piston height has to match the block deck height + gasket thickness,
but I wasn't sure what the various available rod lengths were.
I tried searching but I got all the wrong hits (lol... articles regarding 'rod' and atricles regarding 'length'...).
Also what did you mean with more efficiency? Better VE?
To drive at the same speeds and rates of acceleration as the smaller engine you will see lower rpm and friction with the larger engine. This is why you run huge engines that turn low rpm when you need a lot of power but you need the engine to last forever.
Efficiency means how much power you can make out of a given amount of fuel and air. The larger strokers are always more efficient as evidenced by their lower BSFC readings and their higher power with the exact same heads etc.
