Why hasn't VTEC been adapted to pushrod engines?
)I still fail to see the overwhelming advantage of SOV. Even if they could produce a "square wave" valve motion, which they cannot, that isn't at all ideal for breathing. Varying lift can eliminate the need for a throttle, as BMW has shown, but why bother? Variable phasing, especially with multicam engines, goes a long way toward optimising engine output.
I would rather see variable length intake runners to shape the torque curve (along with cam phasing). It worked well in F1 until it was outlawed for 2006. Renault, especially misses it this year.
If we are going to take something from F1, pneumatic valve springs sounds good to me.
We already produce OEM engines (gasoline, NA) with torque curves having 90% of max torque from converter stall(<2000) to WOT upshift point (>5500). We're headed toward an almost flat torque curve with current technology.
FWIW, flat lifter pushrod engines (NASCAR Cup, for example) have almost point contact between the slightly radiused lifter foot and the slightly tapered lobe. That point moves on the lifter, but the loads are very high, and they live, just as flat lifters lived in OEM engines. That's not really a hurdle lto 3D cams.
A 1.0 sq.in. disk moving .650 in. @ 7200 rpm with a 300 degree (seat-seat timing) duration needs to move the hydraulic oil at a rate of about 48 gallons per minute with no restriction and with a control making changes every 10-40 microseconds (not milleseconds). This is for each valve. That might be a fairly large challenge. Perhaps I missed something.
Dig a little deeper into hydraulics and their controls.
Perhaps we could use tiny CNC ball screws.
I'll leave it to others to figure the pump power, oil tank capacity and cooling system needed to make such a system work. Note that we don't see a lot of hydrauliclly actuated valve on high speed IC engines.
Shoot, high-revving F1 engines couldn't make electrical solenoids work fast enough, and the weight (high up) and electrical power required made the systems impractical even before they were ruled out.
UofMn
They have a camshaft. It's very much like VTEC, with a couple of very expensive actuator gimmicks thrown in... Valvetronic = intake valve variable lift adjustment
Intake air flow is set with the throttle body fully open, and by adjusting the valves on the fly.
Intake/Exhaust cam for each head (4), with an added eccentric shaft higher above and off to the side of the intake camshaft. Two DC motors adjust these shafts.
The throttle body isn't even used 99% of the time. At start up, the throttle body controls air flow. Air flow is also controlled by the throttle body if any faults are to occur in the system.
Ex.
In the event of a motor failing, the motor on the opposite bank will match the failed motors position.
Pretty bad *** setup. Sounds like a lot to go wrong, but so far this has been pretty reliable.
