Advanced Engineering Tech For the more hardcore LS1TECH residents
Why hasn't VTEC been adapted to pushrod engines?
Old Jun 25, 2006 | 06:36 PM
  #101
joecar's Avatar
Originally Posted by menudoman
damn....beat me to it. i had a teacher mention rotary valves to me back in 99. i kinda hoped it would have caught on more by now. seems like a really good idea, especially with the cam phasing technology thats out now.
rotary valves seem like a way better solution to me than SOVs. ridiculous rpm, ridiculous flow, and the valve assembly is constantly turning and doesn't heat soak like a poppet valve setup does. i don't pretend to be an engineer, but seems like a pretty good setup to me. but for one reason or another, it's never seemed to catch on.
I wonder how well a rotary valve seals in combustion pressure (vs a poppet valve seals extremely well with combustion pressure).
Old Jun 25, 2006 | 07:36 PM
  #102
MadBill's Avatar
Rotary valves, like practically every other major variation from a conventional four stroke/poppet valve engine, suffer from sealing and lubrication issues.
Old Jun 26, 2006 | 07:24 AM
  #103
motorman's Avatar
Default rotory valves
they were used a lot on 2 stroke engines where they were needed only on the intake side because the different cutout could be used to change the power band
Old Jun 30, 2006 | 03:15 AM
  #104
RussStang's Avatar
Originally Posted by MrDude_1
where did you get THAT from?
http://www.carcraft.com/techarticles...GM/index3.html
It is likely never to see production, but GM did experiment with a dual cam in block motor.
Old Jun 30, 2006 | 06:33 AM
  #105
motorman's Avatar
this makes more sense than the 3 valve head with the short pushrod that ran across the head to operate the exhaust. this short push rod across the head type was used in the 1939 BMW inlne engine to get a cross flow head design.
Old Jun 30, 2006 | 12:54 PM
  #106
joecar's Avatar
Wouldn't it just be easier and more productive to design in dual overhead cams instead (and it would allow 4V/cyl)...?
Old Jun 30, 2006 | 06:27 PM
  #107
motorman's Avatar
this would make the engine taller,raise the C/G and cause GM to raise the hood line on cars like the corvette
Old Jul 1, 2006 | 12:37 PM
  #108
RussStang's Avatar
4V/cyl are still possible with pushrod engines. The Dominion/Arao SBC heads are 4V. Dunno why GM only went with 3V for this concept engine.
Old Jul 1, 2006 | 03:00 PM
  #109
joecar's Avatar
Yes, I've heard of 4V w/pushrods and seen pictures of similar heads, but the pushrods take up space that the head's ports could otherwise use, and any "cross-rod" mechanism seems to be a contrivance (loses direct motion as the mechanism becomes more complicated).
Old Jul 2, 2006 | 09:53 PM
  #110
THE_SUPRA's Avatar
isnt the new Escalade a vvt pushrod v8?
Old Jul 3, 2006 | 08:41 AM
  #111
Old SStroker's Avatar
The L92 used in the Escalade has variable "cam phasing" which means the advance and retard of the entire cam can be changed while the engine is running. This has the obvious advantages of shaping the WOT torque curve across the rpm band with small advances and retards, but it also helps with emissions and part throttle economy with larger advance/retard. The PCM controls it.
A similar system has been used on the exhaust cam only on the 4200 I6 (Trailblazer) engine for years. On that one the phasing was as much as 50 crank degrees (25 cam degrees).
Cam phasing on a single-cam engine does not vary the intake and exhaust timing separately, of course. Neither is it the sole reason for the 403 hp/ 417 lb-ft of the Escalade engine. The head is similar to the LS7 which is similar to the C5R. It that "trickle down theory" or all part of the grand plan for the GenIII/IV from it's inception.
Old Jul 3, 2006 | 10:14 AM
  #112
JonCR96Z's Avatar
Originally Posted by gen3performance1
gm uses aform of this called displacement on demand.
Wrong. DOD has nothing to do with this thread.
Old Jul 19, 2006 | 07:32 AM
  #113
kabbott's Avatar
Just save alot of engineering and unneeded parts, supercharged 2 stroke no valving needed.see how easy that was?
I see alot of interesting ideas here and would not be supprised to see more than one of them in the next 10 years.
Imagine tuning when you can infinitely control valve duration,lift and timing! cant wait
Old Jul 19, 2006 | 07:43 PM
  #114
ryanbmw's Avatar
Default STRIPSTAR corrction.
hey STRIPSTAR, actually to correct you, on the BMW thing. Vanos is just adjustable time on the cams, but you are right they have adjustable lift also, its actually caled "valvetronic" but you wouldnt really want it on any drag motor just becuase when it broke at the end of the season i would cost about 5 to 6 grand just to replace the adjustable lift mecinasims, and the motors, not to mention cams and other hard parts. but for street vehicles there awsome, because if you work at the dealerhship like me you can caliberate and make some adjustments to give you almost an inch of lift, and on the new v-10 that would make some major power, way above the stock power they put on the street.
Old Aug 5, 2006 | 03:49 AM
  #115
2002_Z28_Six_Speed's Avatar
Wouldn't most of the boost blow through the engine at dead bottom then? That is what it looks like from a model airplane engine.
Old Aug 5, 2006 | 05:32 PM
  #116
bigfoot2thefloor's Avatar
vtec =
Old Aug 16, 2006 | 05:33 PM
  #117
The_Quiet_001's Avatar
I'm guessing nobody here has been to www.pattakon.com. He's got a relatively simple design that allows infinately variable valve lift from completely closed to max lift and anywhere in between. It's a good read if you've got some time on your hands. I've personally found it very interesting.
Old Aug 22, 2006 | 08:02 PM
  #118
Rothman's Avatar
Domestic drivers wouldn't be able to handle the insane, mind numbing power that the Vtec God grants imports. I mean it's like at least a bazillion extra ponies....GOD!!!
No, I know it could actually be awesome. I just had to be a jackass
Wow... deff check out the pattakon site. That is some awesome stuff!!! Almost brings out the mad scientist in me.
Old Sep 6, 2006 | 11:14 PM
  #119
manolis's Avatar
Default An animation for 'VTEC' on pushrod engines
Just take a look at the animation:
http://www.pattakon.com/vva/SideCam.exe
Click the hyperlink above and then Open or Run the file.
Then use the mouse to change the rhythm and the SpaceBar key to change from LowLift to HifhLift mode (only two modes are shown to keep the size of the file small).
In practice, instead of pressing the SpaceBar key of a keyboard, the driver presses the gas pedal and the gas cable rotates the 'control shaft' -that red piece at top - to another angle to get the desirable valve lift.
The typical pushrod engine (V-8, V-10, V-2 etc) is changed to an improved VTEC (instead of two modes the Honda VTEC offers, now they are available infinite modes of operation).
The system works more reliably than the conventional valve train (most of the time the intake valves operate at 1 to 3 mm valve lift).
Thanks
Manolis Pattakos
Old Sep 7, 2006 | 12:47 AM
  #120
WhiteStripes's Avatar
Thanks
Manolis Pattakos
Now that is genious. Why aren't you building engines for a major corporation?
