Advanced Engineering Tech For the more hardcore LS1TECH residents
Why hasn't VTEC been adapted to pushrod engines?
Old May 8, 2006 | 07:10 AM
DavidNJ's Avatar
Default Why hasn't VTEC been adapted to pushrod engines?
VTEC provides two lobes for each valve. One is a mike toast lobe that would be home in a Cadillac, say a 200/204. The other is lobe that would be at home on a race track, say a 252/256. Electronics transition change based on engine speed and throttle position. Other factors, such as MAP or MAF could be used.
The mechanism is an oil pressure powered pin that that enables a more aggressive rocker arm on a different lobe. These or OHC motors.
However, I can envision a lifter with two rollers where the roller against the more aggressive lobe was pinned by oil pressure.
Imagine passing emissions with a car that made peak power near 7k with a camshaft in the 250s!!!
Old May 8, 2006 | 07:24 AM
J-Rod's Avatar
6600 rpm clutch dump of death Administrator
Where are you going to put those extra lobes?
Old May 8, 2006 | 10:05 AM
Domestic Demon's Avatar
Actually they have already adapted Variable Valve Timing for pushrod engines. The new Impala uses VVT on both its V6 engines, and they are both OHV. Its just not as beneficial on a V8, being that they have such broad HP and TQ curves to begin with. So it would help, but probably not enough to justify the added cost and complication of adding VVT.
And for the record, VTEC is a Honda brand name for VVT, it stands for Variable Valve Timing and Electronic Lift Control
Old May 8, 2006 | 10:48 AM
Old SStroker's Avatar
The cheap way to get variable lift and duration is the old "rubber lobe camshaft". The faster you spin it the wilder the lobes get due to inertia forces. You could make the lobe almost anything you want by imbedding little tungsten (or Mallory) slugs in the rubber. Shoot, we came up with that idea back in high school when SBC was still a 283. It didn't work too well then. Maybe the new rubber technology would help.
Old May 8, 2006 | 10:57 AM
NOSjohn's Avatar
Restricted User
Whoa, you are dating yourself now. Where are you from old timer.
I see upstate NY, ever go out cruising? Car shows? A bunch of us hit quite a few of the shows during the summer...one more can't hurt.
Old May 8, 2006 | 11:10 AM
2kSnakeEater's Avatar
duct tape em to the side of the block!
Old May 8, 2006 | 11:45 AM
CTSmechanic's Avatar
Vtec.....Very Tiny Expensive Componets...we have cubes unlike Honda's just a bunch of clutter besides finding a "friend" to smog your car is much simpler
Old May 8, 2006 | 12:09 PM
STRIPSTAR's Avatar
VANOS BMW's technology is the deal. It literally doesnt need a throttle body as its almost infinite adjustmest of the valves.
Old May 8, 2006 | 12:11 PM
white2001s10's Avatar
Electronically controlled lift and duration via solenoid controlled valves would go way beyond that performance & emissions -wise.
Old May 8, 2006 | 12:39 PM
XxGarbSxX's Avatar
Yea, I've heard of experimenting with solenoids. The biggest problem was getting them to last more than like 500 - 1000 miles with the heat from the engine. I'm sure in time they'll have a reliable setup like that, since heat seems to be the biggest limitation.
Old May 8, 2006 | 01:05 PM
Ryne @ CMS's Avatar
LS1TECH Sponsor
yeah but the VVT system that GM is using isnt quite the same as Hondas, GM is just Advancing or retarding the cam shaft as desired, but honda is actually adding lift and duration using another cam lobe as desired.
Old May 8, 2006 | 01:22 PM
Jake99SS's Avatar
It's probably because the Hondas have to make up for lack of cubes. One cam profile gives it more low end to get it going and the other takes over on the high end. V8's don't need any help to get going. If you switch to a big cam and lose low end torque, get some 4.10s.
Old May 8, 2006 | 01:32 PM
LiquidFire350's Avatar
isn't VVT the name that Toyota uses, not that who using what name really matters
Old May 8, 2006 | 01:57 PM
Ballistic Jello's Avatar
Yes, and VVT-i.
The rubber lobe idea sounds wicked, I gotta read about that. Did you or your friends ever actually try that, Old SStroker? What did you mean by it didn't work too well?
Old May 8, 2006 | 02:03 PM
s/c'd cav's Avatar
VVT is used on the new 2.4 eco tec motor , its just a variable adjustable cam gear
im not sure how the V6 works , i havent got to play with 1
and you could split the cam lope in half , and make it 2 seperate 1's , and use a lifter with a doulble roller , and use the oil to press the 2nd roller to the cam lobe
but why ? todays V8's are better than those from the 60's
i never had any success with the rubber cams either , mine got to hot and melted
Old May 8, 2006 | 02:36 PM
Zeus's Avatar
I'm pretty sure they do this on F1 cars already don't they? I remember reading somewhere how F1 cams were made of a special alloy that expands very precisely when heated, thus creating a "bigger cam" during a race.
Old May 8, 2006 | 02:52 PM
Through just a quarter mile race, or a few, or something like a 30 mile commute?
It might be worth it to run a couple races and then change it out, at least a couple times for kicks. I'm pretty interested in this.
Old May 8, 2006 | 02:59 PM
distortion_69's Avatar
What about variable lifters, like the ones you read about in summit or jegs for smallblocks that pump up when the revs get up. I believe they are called rhoads.
Josh
Old May 8, 2006 | 03:26 PM
Jon B.'s Avatar
Nope. The use of any variable valve timing/ variable valve lift system is prohibited.
Jon
Old May 8, 2006 | 03:33 PM
Josh
Correct! Just found this: Rhoads Hydraulic Lifters at jegs.com
For maximum low end torque, engine vacuum and fuel economy, you need a smaller, more efficient cam. But smaller cams rob mid and upper RPM power needed for fast acceleration. For more mid and upper RPM power, you need a larger, more powerful camshaft. But larger cams are murder on low-end torque, engine vacuum, fuel economy and idle quality. With Rhoads Lifters, you get both! Rhoads Lifters work automatically and give you a ''smaller'' cam at lower RPM and a ''larger'' cam at higher RPM for the best of both worlds. How you ask? At idle and lower RPM where lugging power and more torque are needed, Rhoads Lifters ''bleed down'' to make you cam seem smaller by about 10°. This really boosts low-end torque, engine vacuum, fuel economy and idle quality. At higher engine speeds where more cam boosts mid and upper RPM power, the Rhoads Lifters work to restore full lift and duration of your cam for maximum top-end power. As your engine revs higher, Rhoads Lifters bleed less because there is simply less time to bleed at higher engine speeds. Near 3500 RPM, the bleed action has virtually disappeared, shifting back to your full cam and maximum horsepower potential back into action. Here's an example:
Using a hydraulic cam with 280° duration and .450'' valve lift, here's approximately what the valve timing will look like inside the engine at various RPM using Rhoads Lifters vs. stock lifters:
____________Duration____Lift___Duration______Lift
@ Idle________260°_____.425''____270°______.450''
@ 2000 RPM___265°_____.435''____270°______.450''
@ 3500 RPM___270°_____.450''____270°______.450''
Stock lifters don't vary the valve timing. Rhoads lifters do. Stock lifters can ''pump up'' at higher engine speed, drastically cutting power. But Rhoads Lifters actually help to eliminate pump up, adding as much as 500 more usable RPM on the top-end. You can even hear Rhoads Lifters work! They make a mild ticking sound at idle, which tells you they're working to boost low-end torque, vacuum and fuel economy. When the size of your cam is ''reduced'' for more low-end torque, the valves seat at a slightly faster rate, producing a mild, solid lifter sound. This sound gradually dissapears as your RPM increases, ''restoring'' your cam to its full size for maximum top-end power.
And despite this, which I believe:
Jon
Honda's exclusive VTECÔ (Variable Value Timing and Lift Electronic Control) technology was first developed for our Formula 1 racing teams and has now been applied to the BF225 and all-new BF150 outboard. Push the throttle and you'll feel the result.
