Advanced Engineering Tech For the more hardcore LS1TECH residents
How to make torque at higher RPM...
Old Jun 23, 2006 | 02:06 PM
  #161
Old SStroker's Avatar
Isn't it much more fun when you figure it out for yourself?
It is to me, anyway.
FWIW, MEPs (I, B or F) are not something you measure, but something you calculate. As mentioned by a few, they relate how much torque (Indicated, Brake or Friction) is associated with each cubic inch (or cc) of displacement.
With good intake & exhaust tuning an engine (like an open Cup engine and perhaps Pro Stock) may have it's highest VE at/near power peak rpm rather than torque peak rpm. It still would most likely have a higher BMEP nearer torque peak because of increasing friction torque (and FMEP) at the very high rpm hp peak.
Keep the fires in you heads burning.
Old Jun 23, 2006 | 02:13 PM
  #162
joecar's Avatar
Very interesting, I want more...
Old Jun 23, 2006 | 02:53 PM
  #163
DavidNJ's Avatar
Unless you have variable displacement or are converting from 4-cycle to 2-cycle on the fly, bmep has a constant relationship to torque. Peak bmep always occurs at peak torque.
I was hoping for specific engines where the peak bmep was well below peak VE. I would have thought this is more likely in engines with VEs of 105-115.
Old Jun 24, 2006 | 03:30 AM
  #164
racer7088's Avatar
F1 engines make peak BMEP before peak IMEP all the time. Most super high rpm engines do even in Comp when people are really measuring or calculating. An F1 engine right now can make decent VE at quite a bit higher rpm than they are turning at max power but the FMEP is a very large component up there.
Old Jun 24, 2006 | 03:34 AM
  #165
racer7088's Avatar
Thumbs up
Well Torque is what you actually have left at the end of the crank so it IS in fact BMEP. Just because Tq peaks at the crank doesn't mean that VE peaked at that same point. It all depends on the friction and other curves.
Old Jun 24, 2006 | 08:54 AM
  #166
DavidNJ's Avatar
Yes, I know. However, looking at street engine maps it always appears that torque nearly exactly flows VE. I think this is just a factor of the air flow tuning and low torque and power peaks of most street engines. Points at which big, friction not linearly related to speed has reared its head. If the friction was linearly related to speed, than bmep would relate to VE.
Old Jun 24, 2006 | 11:36 AM
  #167
racer7088's Avatar
Thumbs up
Pretty much.
