Advanced Engineering Tech For the more hardcore LS1TECH residents
Nice intake manifold... - The ITB thread
Old Dec 16, 2006 | 11:07 AM
  #161
30thta436's Avatar
Originally Posted by FieroZ34
So what were these "unhealthy" dyno numbers?
It was down about 70RWHP.
Old Dec 16, 2006 | 01:00 PM
  #162
ls1408cp's Avatar
Did you take the filters off yet?
Old Dec 16, 2006 | 01:09 PM
  #163
30thta436's Avatar
Just took them off and and dynoed it again. No changes other then the filters. It picked up 40 horse and 40 torque. So the filters were restrictive. The tune was completely off without the filters also. But we are still down on power from the fast.
Old Dec 16, 2006 | 01:51 PM
  #164
ls1408cp's Avatar
I didnt think those filters would cut it.
Old Dec 16, 2006 | 02:18 PM
  #165
P Mack's Avatar
Do these intakes still use the MAP sensor? I didn't notice any in the pictures.
Old Dec 16, 2006 | 03:33 PM
  #166
FieroZ34's Avatar
What else would they use, Alpha-N?
And if you'd read the thread, we already answered your question anyways.
Originally Posted by Aaron
Most ITBs have either a vacuum line running from each TB bore, or a single vacuum line from each row of TBs. Mine are setup to have a single vacuum port from each row of 3 TBS, so I have 2 vacuum ports total. All I need to do is take both ports, and run a line to a common vacuum plenum. From here I can attach the stock MAP sensor, and all of the other vacuum operated systems (PCV, brakes, FPR, IAC, etc)
Old Dec 16, 2006 | 10:14 PM
  #167
topperge's Avatar
Originally Posted by 30thta436
I did if I turned down the idle stops to far. Which I did, but then turned them up a little. It doesn't stick at idle, but on the dyno I did notice that it stuck at wot for about a split second. It scared me at first, but It may be just me. I got it to idle at 950 perfectly. It took alot of adjusting, but I got it there. I turned it down to 900 and it idled there, but the iac was completly closed. Even with it closed all the way it still idled perfect, even when driving and coming to a stop. I turned it back up to 950 for now and will mess with the idle again once all the other problems are sorted out.
Have you driven yours yet? This one feels like it has a miss just off of idle. After that it feels fine.
We haven't driven mine yet, GTPPrix and Kirk at Vector are my tuners on the car. They've been dealing with the issues and I've been pulling out my hair from Virginia. As long as the intake stays warm the blades don't stick, but after a night the blades have to be tapped to release and open back up.
I'm seeing the same disappointment from this intake though. Mines a 408 w/ ETP 245 heads and a 247/252 .646/.644 113+0 cam. The best they could see was 460 on their Mustang Dyno. The car made 480 with a much milder cam and a Fast setup. This is also wide open with no filters.
Old Dec 16, 2006 | 10:49 PM
  #168
pdd's Avatar
pdd
hope ya get it worked out-interesting thread
Old Dec 17, 2006 | 07:55 AM
  #169
JL ws-6's Avatar
Race your car!
There are guys in aussie land makgin power with these things... I dunno what they are running for cams and whatnot, maybe a phone call to soeone over there might be a help... I'm sure they would be willing to tel you what they are running, or try calling harrop, they probably can steer you in some direction with it.
Disturbing results from teh fliters though.. I can't believe they were that much of a restriction... kinda makes this piece even more of a track only setup, driving around on the street with no filters at all... risky at best IMO. One dust cloud/peble and you're gonna be in for a bad day.
Old Dec 17, 2006 | 03:30 PM
  #170
ls1408cp's Avatar
https://ls1tech.com/forums/showthrea...=473973&page=1
here is post about the harrop. I still think its not as great as everyone thinks it sounds like a myth. At first I thought they would be good but after more research I found nothing but ****. I dont think a cam change is going to make these cars pick up 150rwhp.
Old Dec 17, 2006 | 04:14 PM
  #171
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
There's no way these things are a myth. They'll easily outflow any other manifold on the market. Just the surface area of these intakes over a treaditional FAST style or sheet metal is much greater. 8 x 52mm tbs vs 1 x 90mm, dee de dee. The problem is that so little are custom made to an application. Most are mass produced and not set up to the car they're supposed to be on, they're universal for the engine. Hence all the problems with the Harrop. These intakes just have little problems that needed to be sorted out.
Old Dec 17, 2006 | 04:51 PM
  #172
ls1408cp's Avatar
I am not trying to make it worse I am just tried of people making up ****
Old Dec 17, 2006 | 04:52 PM
  #173
Beast96Z's Avatar
I agree. It's like finding a cam that works with the L92 or LS7 heads. It's just one of those things that needs to be sorted out.
Old Dec 17, 2006 | 06:09 PM
  #174
Phoenix 5.7's Avatar
i think one big issue is that US cam designers don't have much experience with ITB. the Aussie guys with years of experience with these have some downright wicked cams that are way out of the realm of the US cams.
still doesn't explain the big power loss
Old Dec 18, 2006 | 06:41 AM
  #175
11 Bravo's Avatar
ITB's have been around since anyone here was born. I'm sure there are plenty of folks with experience. But my decision on weather I get one of these will probably be based on this thread since it's the only place I'm getting info. Right now it's not looking good. Even if this setup turns out great which I'm sure it will, I really don't know any tuners in my parts that would know what the heck they're doing trying to tune an ITB.
Old Dec 18, 2006 | 06:49 AM
  #176
chuntington101's Avatar
i think people think you can just stick these intake on and drive away! you cant!!!
ITB need setting up propperly. each cylinder needs blancing out and the linkage often needs quiet abit of time sepent on it to get it right!
as for mass produced kits not working?? CRAP! there a a **** load of "bolt on" throttle body kits over ehre (most for 4pots for use in kitcars) and with the riught setup they work AMAZING!!
by the way ITB are not the best method! roller throtles are better (they leave nothing in the intake track at full throttle!!) but are more exspensive!
thanks Chris.
Old Dec 18, 2006 | 09:04 AM
  #177
topperge's Avatar
Originally Posted by Cliff
What I find interesting; I would think employees from Harrop would jump in this thread and help out with the issue we are having. Customer service and technical help would be wonderful. The faster we are up to speed on their intakes the more f-body people would buy their product. They are members of LS1tech but they never give suggestions or tech help.
I just got off with Mike at Harrop USA this morning. They are aware of the thread, but were pretty tied up with PRI last week. I will say Mike has been great about supporting this project. He's got calls into Australia, we should be talking to them shortly.
I'm sure Ken (Tuf383) will jump in here shortly.
Old Dec 18, 2006 | 10:10 AM
  #178
Cobra4B's Avatar
Subscribed! ITB's are teh sexy.
Old Dec 19, 2006 | 07:13 AM
  #179
looks great ArgonZ!!!
Chris.
Old Dec 19, 2006 | 11:10 AM
  #180
JL ws-6's Avatar
Race your car!
Argon that looks pimp, and after seeing how your car project came out, I'm sure this will be a work of art as well. If you need an f body test car for it.. lemme know.
