Will Camshafts Soon Become Extinct?
Just a little more food for thought.
That is actually one of the most attractive things about electronically operated valves. With the TB open you can run down the road with a intake at a higher pressure.
You can also do things like have more square valve events. You can also close the intake valve extremely prematurely at part throttle so the rest of the intake stroke acts like a spring, loading up energy that you can for the most part reclaim on compression.
Also at part throttle you can open exhaust very close to BDC (while still closing at BDCexhaust). what would that do is make better use of the power stroke at low throttle.
I've also read that 42 volt systems could shed a significant amount of wieght in wiring. The problem is its edging on what can be considered dangerous.
Just think about it. ON your intake stroke your doing alot of work by moving the piston down with such a heavy vaccum on it. With electronically opened valves you can start your intake stroke, open your valve really quick while your expansion (volume) rate is high near TDC.. get your little shot of air and then close again. Since all the cylinders aren't fighting for a small piece of air in the intake, the manifold can remain at ATM.
You would be controlling cylinder filling with valve events instead of putting a HUGE restriction on the intake.. that being the throttle body.
http://www.isqe.com/
Correct about the voltage increase decreases the current needed to be moved so the wiring is smaller.
I don't see it as being a real safty issue.
This has been discussed for years. I remember 1st reading about the change that "Needs" to be made to a 48V system back in 1995/96. Car Stereo people have been paying attention to this for years since the ability of the system is roughly 3-4x what's out there now.
http://www.sturmanindustries.com
And on a side note, I played the piano for Penn State's Christmas Party on Christmas Eve (they're in town for Outback Bowl). I got to shake Joe's hand. Pretty cool.
120VAC --> 84.85 VDC. That arguement is very misleading and from your reply it does sound like you didn't even give that thought. Don't play off electricity as a toy. AC is a sine wave so that higher voltage is overrated compared to a DC shock or the average voltage of AC over time.
By the way. You can experience low voltage/high current (short like condition) and high voltage/low current (open like condition) in your body from wet skin vs dry skin respectively. Do you honestly believe that it is still 120 Volts by the time it gets to your heart? AHAHAHAHA Ever heard of voltage divider?
Guess not.Measure from body to ground NOT source to ground. IN YOUR BODY. Look up Kichoff's Law for confirmation. Further, look up current controlled circuits. Your certificate only covers a tightly managed power system. Not the world of the possible. And that's "what I know about this electric."
Unrelated
I love it when people, mostly on the net, condone common knowledge and rub it off as unneeded intelligence or "book-smarts."
I understand that my revision to this post sounds smart allic, however, that is due to the conditions under which other people treated me despite I was diligent and mature with them at first. Text made small as off-topic.
1 mA Barely perceptible
16 mA Maximum current an average man can grasp and "let go"
20 mA Paralysis of respiratory muscles
100 mA Ventricular fibrillation threshold
2 Amps Cardiac standstill and internal organ damage
15/20 Amps Common fuse or breaker opens circuit*
*Contact with 20 milliamps of current can be fatal. As a frame of reference, a common household circuit breaker may be rated at 15, 20, or 30 amps.
http://paultan.org/archives/2005/07/...valve-engines/
