NASCAR rear differential - open?
So do they run an open rear? Well, I know the answer is no because i've seen them do burnouts. I guess the question is "why?"
Anyplace where the engine rpm runs 3 or 4000 from lowest to highest traction will be a problem, so some form of limited slip is used. IF there was traction control in Cup cars
the tracks that needed it would also be the tracks where a locker would be used.Especially on a long high-speed tracks any form of locking diff would cost power. As a possible added benefit for the "plate" tracks (Daytona, Talladega) spinning one tire launching out of the pits keeps the engine from bogging or stalling. Notice how long they are in first gear on pit-out @ Daytona. It's not just used for getting the car rolling. Trying to spin both @ Daytona might be a problem with an engine weaker than most H&C LT1s.
Did you notice that the highest horsepower car on the track @ the Daytona 500 was the stock Z06 pace car?
Steve
the thing about the plate tracks is that they rely more on the draft for speed. the Z could do it without the draft. the true test for it would be if it could hang in the turns. which according to the nurburgring lap times...it should be able to do it without trying. the Z is a better handling car overall. id just like to see the motor stay together with the abuse the plate tracks put on the motors
Daytona and Talladega have restrictor plates. HP is closer to 425 and max rpm closer to 7500 at those tracks.
and i think we made in the 680s hp to the wheels on the chassis dyno.
