Thoughts on Dexcool v.s. Green
. So I am going to flush my radiator this weekend and am thinking of switching to Green antifreeze. But thought why? what are some of the advantages and disadvantages of using dex and regular green? I know dex lasts longer (suposedly)and was made for aluminum motors,and more expensive. Was wondering your educated thoughts on this before I fill my rad back up??
And what is the most effective way of getting the guts of my cooling system cleaned up before damage might occur? I was going to flush with distilled water, let it warm up, then repeat few times.
Basically, the general consensus is split on Dex vs Green. Personally, I'm sticking with Dex. It's worked great for me, so I have no reason to switch.
Perhaps some of the older engine designs use gasket material that was not originally designed to work with dexcool, thus the use of dexcool by GM in later years in these older designs caused issues.
yes, green coolant isn't rated to last as long as dexcool is, but you can't run dexcool for the 5 year change window or else it starts eating seals anyway. so what is exactly the advantage of dexcool if you can't run it for the period it's advertised for, the sole reason dexcool is supposed to be beneficial?people are going to come in here saying that dexcool is less corrosive to an aluminum block than green coolant is. of course, they won't mention how changing the coolant every other year won't corrode the block and how long after they're dead and buried, your block will still be intact, even if the car is rotting in a junkyard somewhere for 50 years. just because it's aluminum doesn't mean the block is fragile. the purpose of using aluminum is that it's very corrosion resistant, lightweight and dissipates heat quickly (aluminum can't rust, ahem).
so why does GM recommend dexcool? well, it's more expensive, and, oh yea, doesn't GM get a kickback for using it, just like they get a kickback for recommending mobil 1 on corvettes even though many other oils outperform it?
run whatever you feel comfortable running. just know that most mechanics hate dexcool and advise their customers to switch to green. dexcool is stereotyped as a bad coolant by mechanics for a reason - it's notorious for gunking up your radiator and eating water pumps. if you decide to switch, make sure you flush out ALL the dexcool. my car was flushed with green coolant FOUR TIMES on the swap, including running the heater to clean out the heater core - don't forget this step.
Most LS1s do not blow out water pump gaskets at 30k miles. Yours would be the exception, not the rule.
There is no major price difference at the local autoparts stores around here for dexcool over the green. And what I like about the dexcool is, my radiator looks a lot cleaner using that stuff than what my older cars did with the green stuff. I change coolant much more often than the 5 year recommendation though. But again, I don't see price as an issue regardless of change interval, because dexcool costs me $10/gallon. No biggy. Green stuff isn't much cheaper.
Some of the engines in new cars that use dexcool now (or in recent years) are engines that were designed before dexcool was standard, so the gaskets might not be fully compatible. 3.4/4.3L motors are not "new".
I cleaned it up but the sludge would reappear of course and then the motor started running warmer. I had the motor flushed out and the green coolant put in it. No problems since. I know more about the situation now but with the green I don't have to worry about the brown sludge.
haha I thought that car looked familiar,we need to meet up soon and go cruise!!
