Tech information for the experts
Any info, or any sources that I could check out would be great. It will be greatly appreciated.
1. Excellent head design of the LS1 that has been continuously and rapidly improved through the LS7. The Gen V engines will move the benchmark farther forward regarding head and valvetrain design.
2. Excellent induction systems for good broad-band power.
3. Excellent electronic powertrain control system.
You need more than a few opinions though. In order to develop your own paper, you will need to do some research and as Brad8266 pointed out, there is a lot of information on the Internet and in print.
All my best,
Steve
http://en.wikipedia.org/wiki/Otto_cycle
Starting there is a good place, then from there it can get extremely complicated, the engineers building internal combustion engines focus on a wide variety of problems and needs of the engine.
The design process for maximum power will have significant attention payed to the rotordynamics aspects of the engines rotating assembly, also, significant time will be spent with computational fluid dynamics to try to work out exactly how to build the cylinder heads and make them flow in an optimum way given a limited amount of space. Then you can get into the chemistry of the air fuel mixture, and even some of the quirkier events in the combustion chamber such as leidenfrost effect or film boiling of fuel on the pistons, the why the air enters and exits the valves is very important.
http://www.amazon.com/Design-Simulat...8221588&sr=1-1
The reasons this engine is superior to the old smallblocks is what Steve said plus better oiling, parasitic drag testing, and better materials to work with. The 15 degree valve angle and larger, taller intake port design aids in better overall power numbers while sacrificing some low end, below 3500, power. The longer rod helps in dwelling at the top to make the cylinder head seem bigger than it is. The taller deck height allows for the longer rod and stroke. The lightweight valvetrain and behive valvesprings help the parasitics on the valvetrain and also aid in the longevity by reducing the stress of the system components. The 6 bolt mains add stability to lower end and the long head bolts keep stresses off of the top of the block which helps in less distortion of the cylinder bore which helps in the overall sealing of the rings. The larger cam bore allows a larger base circle which gives the valvetrain a lot more room to operate efficiently by not having so much acceleration for a given lift. The windage tray keeps oil from sitting on the crank, eating up power and overheating the oil. If you need, I can help out with the differences more. Let me know, I always have time for learning.
If I were doing such a paper I would focus on BMEP and how it is a great way to compare engines of any displacement and use. Things that improve BMEP, especially power peak rpm BMEP for high performance engines are what make one engine better than another.
Good luck!
Another good site on the internet for engine info:
