Advanced Engineering Tech For the more hardcore LS1TECH residents
Highest CR on 93 Octane
Old May 8, 2007 | 06:45 AM
barkingspud's Avatar
Default Highest CR on 93 Octane
Like the title...What would be the highest SCR I could run for 93 Octane pump gas? I tried searching came up with a bunch of hits that were useless. Thanks in advance....
BS
Old May 8, 2007 | 08:37 AM
KCFormula's Avatar
I would like more info on this as well. Although I believe it would have a lot to do with the DCR as well. And maybe combustion chamber shape. Is there a known limit? At what point does using a methanol kit become a good idea?
Old May 8, 2007 | 08:59 AM
Well....I am referring to an NA motor.....DCR is still a factor though. I understand that a DCR of 8.5 or less is preferred.....
Old May 8, 2007 | 11:18 AM
Ferocity02's Avatar
DCR is what you should be concerned about, much more so than SCR. I'd go with an DCR of 8.75 or less with 93 octane.
Old May 8, 2007 | 11:57 AM
yak's Avatar
yak
DCR is what matters most. I would say that 8.7 drc and no more than 12.0 scr with a good tune. btw, where in the western burbs are you?
Old May 8, 2007 | 01:46 PM
Manic Mechanic's Avatar
Barking Spud, This is what they are talking about.
SCR = static compression ratio. The physical difference between combustion space volumes at bottom dead center and top dead center.
DCR = dynamic compression ratio. The compression ratio actually produced during operation. It is a fine tuning of sorts on the SCR. It varies with cam timing, intake manifold tuning, RPM, and load.
You could have a high SCR that convention says won't work on pump gas but with a long duration cam that bleeds off compression at low engine speeds your DCR is lower so it works great. Find a knowledgeable engine builder and or cam grinder. Comparing cam specs for others compression ratios will give you a guideline. If you're just wanting the highest safe number that will work with street cams then the answer is stock.
Vernon
Old May 8, 2007 | 02:26 PM
Vernon
Thanks Vernon...I will have a chat with my engine builder....I'm not looking for something too well behaved on the street......But, I do want to run readily available pump gas though.
Old May 8, 2007 | 02:36 PM
NoGamesLS1's Avatar
I am running 12.5:1 SRC with a trex on CA 91 so you could run a bit more on 93
Old May 8, 2007 | 02:52 PM
Ari G's Avatar
CR is nothing you can calculate accuratly to go with octane number,has to do with so many variables
Old May 8, 2007 | 03:39 PM
hmmmm....I hope my engine builder has a better answer than that.....
Old May 8, 2007 | 04:04 PM
Quick96ss's Avatar
iam running 12:1 on pump gas 93 octane.. Tuned by Speed Inc...
Old May 8, 2007 | 04:22 PM
8ty8 LS1's Avatar
is there a formula to calculate DCR? and or SCR? thanks.
Old May 8, 2007 | 05:19 PM
Ferocity02's Avatar
Whats your DCR and timing? You can run as much compression as you want, but without high octane fuel you will have to cut down a lot on timing, it's just a trade-off.
Old May 9, 2007 | 11:53 AM
383Z4ME's Avatar
This is a pretty good write-up with a link to a calculator at the bottom.
http://members.uia.net/pkelley2/DynamicCR.html
Old May 10, 2007 | 11:21 AM
Ferocity02's Avatar
SCR is pretty easy to calculate by hand, it's just volume at BDC over volume at TDC. DCR is much more difficult to calculate though as it takes into consideration valve timing, rod length, as well as the volumes from the SCR calcs. Definitely tedious to do by hand. If you search for DCR calculator on google you will find plenty.
Old May 10, 2007 | 11:53 AM
2fast97Z's Avatar
my old lt1 383 was 12.5:1 and i ran 93 and it was a daily driver and tuned by madz28..never a problem
Old May 10, 2007 | 12:21 PM
KCFormula's Avatar
How big of a cam did you have? I wonder if the guys with the Trex are getting away with it because by nature it bleeds off a lot of compression?
A local guy is in the high 13s:1 compression and he runs a mix of 104 and pump gas depending on the weather but he also has a Trex.
Old May 10, 2007 | 07:32 PM
MadBill's Avatar
Originally Posted by Ferocity02
.. If you search for DCR calculator on google you will find plenty.
Or, just read the sticky at the top of this Advanced Tech Page: https://ls1tech.com/forums/advanced-engineering-tech/394937-updated-valve-event-dcr-scr-header-length-spreadsheet.html
Old May 11, 2007 | 02:38 PM
kars10_4's Avatar
tech memeber
Does the rule of DCR being below 8.5 only apply to higher performance engines? Because I found the LS1 in stock form to have a DCR of 9.52 using the link provided by 383Z4ME.
Old May 14, 2007 | 07:52 PM
2fast97Z's Avatar
I had the LE4 Cam
