Still pushing water.
Eric told me to tq mine to 75 no more and there holding great. i would think if you over tq them you will get the boltpart of the head bowing in and the middle of the cylander on the head higher. but im no expert.
I would start at 12* and work your way up.
Are you using a progressor? or spraying it all right out of the hole?
Those heads can take it and as long as the block is Iron it'll take it.
Also did you Tq and loosen the heads sevral times before final TQ ?
Thats what i was told also..... N2O is violent.....
I know im a boosted car.... but i would lift the heads and push that much also....... heads would lift 6-7 times and finally blow the gasket.... not o-ringed though....
Like i said above im in the process of doing it now.... looks like you talked me into 1/2" studs....
Kyle
Kyle
That sucks man.......
Well either BBC time or LSX... id say wait and see what some do with the LSX stuff with the 6 bolt heads and you have almost all the parts except the heads and some bolts.........
Kyle
