Oil PSI vs. Volume
Another example: WHy is it bad when you have high blood pressure? Because the volume of blood is not getting where it should. The veins are restricted.
David
"...with all other factors being equal, the greater the difference in pressure between 2 points in a system, the faster the fluid will flow."
In our engine, the change in pressure would be (~40psi - 14psi), where 40psi is the pressure made by the pump and 14psi is the atmosphere. According to the text, if I made the oil pressure greater, the fluid would flow faster.
Make sense?
Given two identical systems, observing an applied increase in pressure in the closed system implies that indeed, flow velocity is increasing, thus the flow rate is increased.
The 1st law has nothing to do with the OP's question, unless you want to figure out how much energy your expending, and I don't got a lookup table for SAE10w30, nor specs for a LSx oil pump.
to the OP; read here to get a better understanding of the concepts,
http://www.pc-education.mcmaster.ca/...ation/flow.htm
But, these things are meaningless. What you need to be most concerned with is the velocity and flow rate. Oil is effectively incompressible, i.e. compressibility factor = appx 1.
The oil pump does not do create pressure, it merely moves oil. Its the engine bits itself that create the flow path obstructions; i.e. introduce pressure.
So in summary, there is no relationship between "oil pressure" and the volume. Your hosed unless you know the flow rate of the pump. Which is basically what you wanted to know anyways I think (?).
But for simplicity sake and your peace of mind. If you have pressure, oil is flowing, and it's encountering parts in the engine; this is good. If you have no pressure, and the engine is operating, this is NOT good.
So for simplicity sake, you have two cars, identical oiling; everything identical. You change pumps, and now your reading 2x the other cars pressure. You have just increased the flowrate a considerable amount, because the oil flow is now "fighting" harder against the obstructions, this is indicative of more flow squeezing through.
