Audi FSI Technology
I've read it a couple times now but I'd like to spark a pro's/con's discussion, as I already have a couple of questions that maybe others can answer.
In stratified charge mode...
1 - If the fuel is vaporized in the chamber, wouldn't it require a lot of time to allow for this vaporization before ignition (since usually it's already done before it enters the chamber)? If so, they say the fuel is sprayed in the compression stroke, which doesn't seem like it allows for much time before ignition to get this done.
2 - "An additional benefit: during combustion, a layer of air insulates the hot, ignited mixture from the cylinder wall. This cuts the amount of heat lost to the engine block and increases the engine's operating efficiency." ... but as this charge burns and mixes with this extra air, would that not cause it to burn hotter (less fuel and more air = hotter burn, right?)?
#2-- I think applies to light load conditions.
Audi is NOT the only manufacturer experimenting with this technology. I'm very curious how this turns out.
as for the vapourising, have you seen the injector preusres they run?? very very high, almost that of diesels i think.
and as gametech says their not the only ones doing it. be nice to see if there is any advantage on the performance side of things.
Cheers Chris.
Now, if only the turbo would run in a linear rate
http://www.highperformancepontiac.co...injection.html
It seems as if GM is differing by spraying on the intake stroke, rather than the compression stroke like Audi.
