Someone explain (my head hurts)
0 lobe lift * any ratio still = 0 total lift.
The higher rockers will increase the time spent off the seat for higher lifts, but will not change total duration.
it doesn't change actual duration, the cam lobe determines that and that [cam lobe] is fixed. it doesn't allow the valve to open sooner in regards to duration, but at any point within the given duration the valve will be opened more... because you're rocker ratio is a multiplier. higher ratio = greater multiplier = more lift for a given amount of lobe lift.
the downside of higher rocker ratios if you want to get technical is that you're increasing the acceleration rate of the rocker tip, the valve, valve spring retainers and keepers. The more mass and higher the rpms, the greater the forces and the likelihood the rockers and rocker studs start deflecting and eventually break, on top of using correct springs that can handle that acceleration and extra amount of lift.
the location of the pic is http://img2.freeimagehosting.net/ima...8fba0fe893.jpg
it's an excel graph showing lift differences for 1.5, 1.6, 1.7 1.8 1.9 and 2.0 rocker ratios.
it ought to answer all your questions
A bigger rocker does not change TOTAL duration but yes a bigger rocker will change .050 duration.
You kinda it sound like max lift has something to do with PTV clearance, which it does NOT. I understand you're basing it off 2 different lobe lifts, but the way it read to me, I just wanted to state that, not trying to say you're wrong or anything. Maybe it just didn't sound right in my head.
