Advanced Engineering Tech For the more hardcore LS1TECH residents
C5R Kaboom PICS
Old Jun 24, 2008 | 03:07 PM
  #81
TT632's Avatar
Just some thoughts,
You have the hard parts? If you have a clean enough piston check the piston to wall clearance and your ring end gaps. If they are too tight you will know right there.
Its like the Chicken and the egg; too hot of plug, a little too lean and you have detonation, cylinder pressures and temps go through the roof, Tight ring end gaps close up due to excessive heat, The increased friction causes additional heat, the piston over expands, and the rod/wrist pin gets pulled from the piston as it locks up in the bore. With detonation and the associated high Pressures/temperatures this can still happen with a "loose" engine.
If the clearances are fine you can look back on tuning, plugs, fuel system or elsewhere.
One things for sure, no one is going to raise their hand and say it's their fault. Thats why race engines typically don't have a guarantee.
Old Jun 24, 2008 | 03:54 PM
  #82
INVISIBLEZ's Avatar
subscribing...
Old Jun 27, 2008 | 07:26 PM
  #83
Nimitz87's Avatar
wanting to see the conclusion, hope the OP gets everything worked out...thats alot of money for sure.
Chad
Old Aug 8, 2008 | 12:17 PM
  #84
Old Geezer's Avatar
Question Where are
we today??
Old Aug 8, 2008 | 01:16 PM
  #85
strokerblackhawk's Avatar
ouch that sucks
Old Aug 8, 2008 | 02:31 PM
  #86
Vertigo's Avatar
hummmm I've heard so many good things about Futural... I'd say innocent until proven guilty. It's too easy to judge based on one side of the story.
Old Aug 8, 2008 | 03:26 PM
  #87
squee's Avatar
I'd usually tend to agree, but I've also heard several horror stories, such as this. All sound very similar...I've been debating on who to take my car to once I get the new engine in it, and when it comes down to Thunder Racing or Futral, I think I know which way I'm going now...Regardless of whos fault this was...
Old Aug 11, 2008 | 06:08 PM
  #88
Z06 CU's Avatar
All machine work has now been finished. The Jesel belt drive cam cover is different on the LSX vs C5R block. New cover had to be ordered. Took a while for the repairs to be made on the crank due to the damaged mains and rods. Went with different rods this time. Motor will be finished at end of week. Vengeance will install motor and trans the following week if they have an opening.
Old Aug 11, 2008 | 07:11 PM
  #89
SLowETz's Avatar
Damn it Bobby!!!!! Get in line!!!! LOL! .......... j/k!
At least Purple Hope will be in good company
Two broke hotrods side by side ought'a look real good
Were both in good hands
Old Aug 11, 2008 | 09:06 PM
  #90
Z06 CU's Avatar
I have been told Ron can handle two rods at one time, lol
Old Aug 11, 2008 | 09:51 PM
  #91
cam75w/ls1's Avatar
My moneys on Vengeance! Ron's great to deal with. Just got a bunch of stuff for my build from them.
Old Aug 11, 2008 | 11:01 PM
  #92
bww3588's Avatar
Old Aug 12, 2008 | 06:26 AM
  #93
Old Geezer's Avatar
Sounds like things are "movin along". That's great!
Old Aug 12, 2008 | 04:09 PM
  #94
SLowETz's Avatar
Yeah.... I saw that in a bathroom once myself
Old Aug 12, 2008 | 08:08 PM
  #95
Z06 CU's Avatar
It has been nice having people talk with you about what is going on with your build. Almost on a daily basis you receive a phone call with a update. Pics are sent and when all is completed you receive a Build Sheet.
Old Oct 21, 2008 | 05:03 PM
  #96
njc.corp's Avatar
What eneded up happening-
such a shame-people even struggle to afford all this good stuff u have
Car and everything else looks good-
would be interested to know whats going on as i am looking and thinking of doing a c5r based engine-
Thanks
Old Oct 21, 2008 | 10:19 PM
  #97
Ron@Vengeance's Avatar
Ironic this post was brought back to life....
Below is a link from a lil Test n Tune @ Commerce Dragway this past Monday....
http://www.youtube.com/watch?v=8ks3tPey7FA
Not too shabby for a shakedown run
Old Oct 22, 2008 | 12:22 AM
  #98
njc.corp's Avatar
Did not mean to bring it back from the dead ron-
i was just doing some c5r reading and came across this thread-
i could not help it and i had to put my 2 cents in saying how upset i was to see those bad pictures-
but it seems to be on track
what other plans do u have for it ron? more testing or she is right to be raced now?
Thanks for the info and the youtube link--
Old Oct 22, 2008 | 06:20 AM
  #99
770Guy's Avatar
I will wait and let my father (ZO6 CU) give more detail but......
After all the complaining about how the transmission was a piece of crap and wouldn't stall. With some tuning from someone who knows what they are doing with BS3.
Its amazing that the tranny stalls to the correct rpm now......
Same transmission
Same Torque Converter
We are about 150lbs heavier than we were also. (LSX block etc..)
Lower compression and much lower timing
I think I can say I rest my case, its pretty obvious. Its way to funny that this thread got brought up literally the day we got to make a pass with it.
Thanks of course Mr. Ron Mowen for posting this video.
Old Oct 22, 2008 | 06:58 AM
  #100
njc.corp's Avatar
Smile
Same transmission
to put the myth of me bringing this thread becuase i wanted to push some buttons-
do a search on the c5r ? i have been asking lately-
i am also oversea's so i just dont know what u guys are doing-
like i said just doing some reading-
i wont get in the bad bitch he said that he stuffed that debate-
its good to see it's all up and running-
but i will say the car and the products are top stuff-
Thanks
