Advanced Engineering Tech For the more hardcore LS1TECH residents
Non DOD replacement lifters
Old Sep 2, 2008 | 04:51 PM
scooter k's Avatar
Default Non DOD replacement lifters
Don't know for sure if this is posted in the right section?? I'm trying to replace the lifters in a 2008 Chevrolet 6.0. Anyway I'm wanting to take the DOD or AFM lifters out and replace them with conventional lifters. Can this be done? Will LS6 lifters and lifter trays work? I haven't tore into it yet but did know that the cylinders with the DOD lifters are keyed so you can't put a regular style lifter in that hole. I'm thinking the tray is the only thing keying that. Correct me if I'm wrong but any help is welcomed. I have the DOD tune out so it stays off but don't know for sure on the lifters.
Old Sep 2, 2008 | 07:04 PM
HSV-GTS-300's Avatar
LS Series Camshaft Lifter Kit
• Set of 16 lifters for LS series engines
• Same lifter used in LS2 and LS7
Head Gasket Pair
17800568
Cylinder Head Bolt Kit TTY
• Kit of 15 bolts for LS Series engines produced from
January 2004 and later
• Bolts are 5mm shorter than previous design
(2) required
12558573 LS Series Header Gaskets Pair
17803305
Lifter Guide Kit
• Includes (4x) lifter guides and (4x) bolts
• Makes for quick and easy cam swaps without having to
remove the intake manifold, valley plate or heads
• Works in Gen III and IV applications (except with AFM)
or
LS2 Lifter Guides 12595365 (Qty 4 req).
Old Sep 2, 2008 | 08:24 PM
scooter k's Avatar
I've been told that I need to replace the valley cover and block off afm oil feed ports with o-rings, anything on that??
Old Sep 2, 2008 | 08:36 PM
12570471 LS2 Valley Cover
Those 8x O rings underneath block off the previous oil supply from the L76 Lifter Oil Manifold Assembly to the Collapsible DOD Lifters. Some engine builders additionally like to tap threads into these galleries and plug them with (Qty 8) 1/8"NPT allen plugs.
Old Sep 2, 2008 | 09:27 PM
scooter k's Avatar
So I can use the LS1 style valley cover and those o rings and such come with that cover. I won't put the allen plugs in since the shavings will be in there and block won't be out of the truck so clean up will be hard.
Old Sep 2, 2008 | 09:29 PM
scooter k's Avatar
What about push rods? I can use the hardened 7.4?? By the way thanks for your help, knowledge and pictures too.
Old Sep 2, 2008 | 10:03 PM
Naah it's the LS2/LS7 style valley cover you need. It comes with the O rings as pictured above. The tube coming out the front is the PCV system....connect it straight to your intake manifold.
aaaar carp I'll PM you a link for the whole job.
Old Sep 2, 2008 | 10:19 PM
scooter k's Avatar
Thanks that is exactly what I have been looking for! What needs to be done with the oil pump. Just says pay extra attention to the L76 oil pump??? Do I need a different relief valve??
Old Sep 2, 2008 | 10:23 PM
scooter k's Avatar
What do you think, pull the motor or leave it in? I'm also replaced the the torque converter and if I need to pull the pan it probably will be easier just to yank it?? Do recommend going with a different oil pump or use the stock? I already have the cam gear and timing cover since I'm deleting the VVT. The sad thing is that the truck only has 3500 miles. My wife is sick
Old Sep 2, 2008 | 10:28 PM
Another PM on the way
