Just a Thought...
Old Dec 13, 2008 | 03:19 PM
HMERacing's Avatar
I like the 2nd one. Just try it and see if you like it. I don't think it would be much more than cosmetic though.
Old Dec 13, 2008 | 03:42 PM
Rai's Avatar
Rai
if made right, it could be very functional. it would make the best type of ram air intake i could think of.
Old Dec 13, 2008 | 05:06 PM
phantomzer0's Avatar
Here is a chop I did up real fast. I used an lt1 with a Sunoco because of how similar and how much closer it looks to the c6 then the ls1 style cars.
Anyhow, I kinda like it! I left the glare around the scoop and extended it up a bit around the Sunoco cowl. I only changed the size of the image, so you can see just how close it really is!
Old Dec 13, 2008 | 06:11 PM
Rai's Avatar
Rai
i think we(ls1tech) should contact VFN fiberglass with this idea
what do you guys think?
the scoop should be "deeper/larger" than the C6 Z06 scoop because of the increased size of the sunoco cowl(compared to the stock C6 hood cowl)
Old Dec 13, 2008 | 06:15 PM
The Batman's Avatar
i like that lt1 with the scoop
Old Dec 13, 2008 | 06:20 PM
94'BLKBRD's Avatar
looks good to me
Old Dec 14, 2008 | 09:39 AM
HMERacing's Avatar
"IF made right" There is so much obstruction right where you are placing it. It is not like the vette that the hood opens forward so there is no latch mech sitting right in the way. You have supports and latch assembly right there.
and then the core support. I would think it would be like a FTRA kit that went down then forward instead of straight down. Either way, I like the looks of it.
Old Dec 14, 2008 | 10:53 AM
FamousZ's Avatar
I think it looks out of place... I know because im not used to seeing that on a Camaro, but it doesnt seem to fit..
Old Dec 14, 2008 | 11:46 AM
Adam_346's Avatar
not a fan
Old Dec 14, 2008 | 12:30 PM
Grn4fbody's Avatar
I really hate the stripe, the bummper insert is the better of the two I guess
Old Dec 14, 2008 | 12:54 PM
hlaalu's Avatar
id like to see the scoop maybe a little bit larger, and right up into the hood
Old Dec 14, 2008 | 01:07 PM
  #32
Z28JLR's Avatar
No stripe, Go for the scoop! I think that would look sweet!
Old Dec 14, 2008 | 01:17 PM
  #33
hlaalu's Avatar
ive been messing around with a few ideas and the only problem i see with this being functional is the hood latch. so i guess a pin on hood would be the way to go
Old Dec 14, 2008 | 02:47 PM
  #34
ryonyanko's Avatar
I'd like to see more pics, I think I like it, i'd never do it however (not getting cowl) moar chops pls!
Old Dec 14, 2008 | 05:31 PM
  #35
Lotus289's Avatar
I really like it so long as you keep it to a low profile a la C6 Z06. It'd look really bad if it were as deep as it looks in the last pic.
Old Dec 14, 2008 | 06:06 PM
  #36
hpjunky98's Avatar
Ive had this same idea ever since I saw the new zo6, but I have no idea where to begin to make it happen... I think it looks great
Old Dec 14, 2008 | 08:21 PM
  #37
Rai's Avatar
Rai
if you have the money you could get a replacement c6 z06 bumper off ebay
or
you could contact a company that makes reproduction c6 z06 front bumpers and have them use the molds to get you just the scoop
then hire a good body work guy to glass it all together
i know both ideas are very impratical, but they would get the job done.
Old Dec 14, 2008 | 08:31 PM
  #38
sweetbmxrider's Avatar
eh i dono. a little more tweaking might make it happen.
Old Dec 14, 2008 | 08:32 PM
  #39
PERFECT Z28's Avatar
I thinks it would be mostly just for looks cause if the scoop was too close the the hood it might cause the hood to "lift" due to the fact of the increased air flow under the hood if not used to a RAM AIR effect.
Old Dec 14, 2008 | 08:52 PM
  #40
hlaalu's Avatar
i think it would be fine if it was a sealed system.
