Ground effect idea
Old Nov 21, 2008 | 02:31 PM
94T/A5.7LT1's Avatar
Default Ground effect idea
For people who are running a front splitter i was thinking of how about adding a piece kinda like a splitter but for the side ground effects so its a smooth transition from the splitter down to the side of the car. Its a big picture but like what GM put on the ZR1. Figure it serves a purpose since GM put it on the corvette that maybe it will work for our cars as well. Opinions on this?
Old Nov 21, 2008 | 04:31 PM
02gtp4now's Avatar
the only purpose i can think of for those is to help keep the tires from throwing **** all over the car, plus they wont look that good on our cars
Old Nov 21, 2008 | 05:18 PM
Rai's Avatar
Rai
i think i like the the aftermarket c5 side skirt better
Old Nov 21, 2008 | 05:29 PM
Brian2006's Avatar
I actually think that would look especially well on camaros without ground effects.
Old Nov 21, 2008 | 05:53 PM
my bandit's Avatar
well we need 6LE to figure something out
Old Nov 21, 2008 | 09:05 PM
02TransAm/Batmobile's Avatar
I think this idea has some potential. I like the idea!
Old Nov 21, 2008 | 09:30 PM
raptorws6's Avatar
I think that would be a great idea.
Old Nov 21, 2008 | 10:16 PM
98 WS6's Avatar
***Summoning the Almighty 6LiterEater***
Old Nov 21, 2008 | 10:21 PM
i think i'll try something like this when i get my splitter on.
Old Nov 23, 2008 | 10:24 AM
FamousZ's Avatar
I like this idea.. I really want a splitter, so this idea might be part of my look aswell..
Old Nov 23, 2008 | 07:46 PM
6LITEREATER's Avatar
Been working on it for awhile for another member. It is VERY easy to get made, not so easy to mount.
All I had to do was the cardboard trick again to get the design, then have it cut from the same ABS, no biggie.
My obstacle so far is mounting. The splitter mounts using 8 FACTORY holes (so you can unbolt 8 10mm bolts, replace them with mine and you are good) and only 3 holes you have to drill that are easily accessed (to attach with a nut).
The problem with the side diffusers is finding a way to mount them. Even if you just drill 5-7 holes to mount them you still have to find a way to access the other side of the sheet metal to affix it with the washer and nut.
I have the ability to make the skirts no problem, just don't know how to successfully mount them...
Old Nov 23, 2008 | 07:52 PM
FamousZ's Avatar
Well you could probably mount them to the same points of the bolt on SFC's... They use 3 or 4 i believe.. I have them but cant remember how many bolts it took..
Old Nov 23, 2008 | 08:00 PM
Nah, the SFC's are in past the sheet metal/welding tab...
Old Nov 23, 2008 | 08:06 PM
blindxeyed's Avatar
When I put my side skirts on (converted to T/A body panels) I just used self tapping screws and washers to attach it to the underside. Holds it up with no problem at all, and is very secure. Anyone that has a drill could easily do it their self. Just a suggestion.
Old Nov 23, 2008 | 08:07 PM
Devylyst's Avatar
**Builds a 6LE Shrine**
I think that would look bad ***
Old Nov 23, 2008 | 08:13 PM
And a VERY GOOD suggestion at that... Sometimes the simplest ideas (self-tapping screws) don't find room in my mind
I'll take another look at the frame tonight and see how much damage that would do...
As long as I can mount it to the non-painted surface with them I think we're good to go
Old Nov 23, 2008 | 08:52 PM
turbowhistle86's Avatar
I'm just throwing something out there....if they are fairly light, could you mount them with 3M tape? I know its not the most secure thing, but it could be an alternative to drilling holes. The self-tapping screws seems like the #1 choice though.
Old Nov 23, 2008 | 09:43 PM
Big Bird WS6's Avatar
any photo shop pics?
Old Nov 23, 2008 | 10:55 PM
had a good idea just wasnt the first. saves me time and trouble. got pictures of what you got so far?
Old Nov 23, 2008 | 11:17 PM
PERFECT Z28's Avatar
Lets see some rough designs
