Window leaked while in car wash
Had the T/A the other day and since it was pretty cold out, I took her to my favorite touchless car wash. As the sprayers would go by, water would enter the car through the back of the window and door. Towards the rear of the car. I realized this is an "extreme" condition with the high pressure water and all but should I look into replacing the weather stripping? I made sure the door was tight and the window was fully up after the first pass and it didn't make much difference. Car is a 2002 WS6 with 100K+ on her.
your windows might need re adjusted that fixed all my leaking problems.. they need to go up higher i have a write up i will post it when i get home in a few hours.
Where the window meets the pillar, there's actually some metal under that weather stripping...that spot tends to be where rear passengers grab hold to get out of the back seat and they end up pulling it back causing a gap between the rubber and the glass when you shut the door. You should be able to make the gap smaller by just pulling that back out. I'll get some pics tonight to show what I'm talking about. My boyfriend actually did it for me so I'm not 100% sure if he pulled the stripping back or not to do it.
