starter button instead of key?
<strong>I saw something at the Chicago Auto Show that I really liked. The Mercedes S500 has a starter button on the shifter. I'm just wondering what it would take to wire something up inside an F-Body to do the same. So you'd basically turn the key to the on position then hit a button to start. My boss reminded me that I probably wouldn't want the button on the shifter. I hate to think what would happen if I kicked the starter on when the engine's spinning above 6000rpm.</strong><hr></blockquote>
First you'd have to take apart the ignition in the steering column..
Thats easily done..
Park the car somewhere in chicago for a few hours.
Your ignition will be taken care of by the local 'mechanic's for free!
After you watch em finish their work, Yell "thank you!" ..they may run away, but at least that part will be finished.
<img src="gr_grin.gif" border="0"> <img src="gr_grin.gif" border="0">
I think a push button starter just left of the stereo or in the center console would be cool!!
<strong>I've got the faceplate for the convertible switch and have the switch itself on order. I'll be wiring that so I can have the antenna down while I'm listening to CDs. There's enough room on the faceplate for another switch or a button. That may be an option for the starter.</strong><hr></blockquote>
Far out!!!!
You GOTTA let us know how it turns out and HOW its done!
<strong>Hey, I have the push button starter from the S2000 in my car. Its to the left of my TCS button. I'll find the picture as soon as i get home.....</strong><hr></blockquote>
Saw the button you set up on the Sounddomain site. Looks good! That's exactly where I was going to put mine. Where did you tap into the ignition wires? What color was the wire for the starter?
NataSS
I can either use that or just start it as normal. It is kid of a novelty thing...
Chicks think its cool <img src="gr_grin.gif" border="0">
pretty useless for anything else though...
I mpounted mine next to the TC on the console.
Good luck
I just installed one under my hood as a "bump" switch to adjust valves.
You need a pushbutton switch that is rated at least 20 or so amps that can handle 12volts. I got one from Jegs.
Drop your underdash. From the ignition cylinder you will see a group of heavier gauge wiring.
The starter wire is Yellow. The 12v wire is Red.
All you need to do is wire one end of the switch to each wire. So when you press the switch, 12v is sent to the starter wire cranking the car over.
You WILL need to have your key in the run position. TO power up ignition/acc and for the vats system.
Years of installing remote starts pays off <img src="gr_images/icons/wink.gif" border="0">
Hope this helps..
Russ
I at first thought I'd have to run the 12V source wire through the switch. I had cut it and turned the radio on to test. Problem was it stayed up with the radio off and the wires apart. Put them together and the antenna went down. I secured them back together and went to work on the remote turn-on wire.
This one worked. Now I just had to find which tines on the foglight switch to connect them to. For anyone considering doing this mod, there are a set of three and a set of two. Use the set of two. The 3 are for the lights in the switch, one for the foglight pattern, one for the amber "on" light and one for ground I'm guessing. I'll wire these later on.
I used snap connectors on everything and it feels secure. In order to use these though, you have to cut away the plastic that would hold the wiring harness in there.
I used some adhesive to hold the switch in the faceplate (from 'vert F-bodies) I bought. It's a snug fit but it doesn't snap in there like the 'vert switch does. I'm just waiting for that adhesive to dry and then I'll go back down and put everything back together. I have about a foot of slack so I can remove the console without pulling anything loose.
Once I get a starter button from Summit I can get to work on that.
