Better grip for better handling
Any types of materials I should look out for which would still provide grip when the wheel is a little moist from glistening hands?
when i turn the car i typically use two hands, that's just how i was taught by my dad... sorry i cant help any. good luck though!
http://www.afterthoughtsauto.com/whe...one-cover.html
Like isn't it pretty obvious what to do? You need to slow down a bit, there's no reason you shouldn't be able to hold onto the wheel while making a U-turn. I don't know many places where making a 30MPH U-Turn is safe, and if you aren't making speedy U-Turns, maybe you need to work out a bit more and grab the wheel a little harder.
But if you really want to change it, get one of those steering wheel covers with the weird *** plastic things made for grip.
I guess no one really understands what im trying to say. well check out this video..
http://www.youtube.com/watch?v=zs7YW...ext=1&index=42
0:47 seconds into the video. He is only using one hand to spin the wheel at first. This is what im trying to explain. He uses more of his lower palm, while I use more of the upper palm, i guess, right below the finger.
If you can't hold the wheel, make U-Turns with two hands.
Never had a problem either..if its bald as you describe get some kind of cover for it maybe
