need some advice on waxing please!
https://ls1tech.com/forums/appearanc...lkthrough.html
Claybar what it does it removes dirt, grime, and bumps from your paint. Basically takes all the contaminats off the paint and smooths it up again.
Wax, well, that is a big debate. I love NXT so i will let other people chime in about that.
before i put my car away for winter i washed my car with dawn. i used Meguiars Step 1 which is a cleaner wax. It removes fine scratches and swirls. I applied this all by hand, and took it off by hand. Then i used Megiuars NXT wax. I applied it with a buffer using a microfiber towel, removed it with the same buffer using a terry cloth towel, then i used my microfiber towel and polished it by hand jsut to make sure i got all the wax off
Here are my results:
I think buying the Zaino and other expensive waxes are a waste when i can get the same result from claying, using a cleaner wax then using a great polishing/sealer wax
But i used Step 1 (cleaner) b/c it removes fine scratches and swirls. Then i used liquid NXT. I think i am going to try the paste NXT waz now....
