Storing The Car For Winter - Preparation Walkthrough
Maybe just maybe this can be a sticky??
Here is the process that I took for storing the Trans Am. I will be as detailed as possible
- Fill the gas tank ALL THE WAY UP, and add a bottle of Sta-bil or Seafoam to it.
- Do an oil/filter change like you normally do, as well as fuel filter change. I am sure none of you changed it all year, now is the perfect time.
- Wash the motor. This is merely for your own sake of knowing that you have a clean motor under the cover. Also a clean motor is happy motor
- Obviously dry the motor, take it for a nice drive for A) to get rid of any standing water and B) this is the last drive of the year
- Wash the car with Dawn dish soap. Yes this will take OFF ANY WAX on the car
- Dry the car. I prefer to use a leaf blower and a microfiber towel
- Clay bar the car. This is designed specifically for above surface bonded contaminants, such as tree sap mist, industrial fallout, over-spray, road dirt/grime and road tar.
- Re wash the car again
- Dry the car again
- Wax the car with a wax of your choice; this is a no brainier step. Do what you normally do here!
- After your done with the Exterior, now for the Interior. Detail the interior. Clean the dash, clean ALL glass, and vacuum every inch of the car.
- This step is where I clean my wheels/tires. Wash the tires to get rid of any tire shine. Then I dry the rims, and polish them. I would not add tire shine when putting the car away for winter.
- Go over the car again to see if there is any water dripping from the rear taillights, under the mirrors etc, etc
- Air the tires up to 45 PSI, this will help stop flats spots being created for sitting in a particular spot for a long period of time.
- DO NOT JACK THE CAR UP! It is not good for the suspension, leave it on the gorund!
- Go over the car again, just spot-check everything.
- Don't forget the Damp Rid from Home Depot. This product takes any moisture out of the air inside the car. it fits perfectly in the cup holder of the center console.
- Stuff towels in your tail pipes and e-cut out. You do not want any critters making that their home
- At this point either A) disconnect your battery and take it in for storage or B) hook up a battery tender to it.
- Time to cover your baby up for a long cold 6 months. At this point kiss the car and say good night
This is all that I can think of for right now. If you guys have anything else to add or feel what I described is wrong let me know. And as for starting and driving the car, that is up to you. if you do that, you need to get the car all the way up to operating temps and drive it for a good 20 miles. This way you will burn up any condensation that is in the lines.
Tailpipes covered by cover:
And the wheel dollies:
Im gonna miss her, but it keeps the miles down!
Never really thought about the dryer sheets in the engine bay.
Also i would like to get the wheel dollies. Where did you get them from.
I just put my stock rims/tires back on, the tires are pretty bald so i dont care about flat spots
- Fill the gas tank ALL THE WAY UP, and add a bottle of Sta-bil to it.
my garage is not temp control
Thanks
