painting engine bay
if you arent doing a color change, then it will be cake, as the spots you DO miss wont really be noticable. you can do it with the motor in the car obviously. through a sheet over the motor and then pull back/tape all the wiring.
i did mine in single stage bc the paint is cheaper, touchups are easy, and its just faster to spray bc you dont hafta clean the gun for the clear.
it will also look 10x better if you take the time to hide all the wires and everything else. less is more. also, painting the fenders and leaving everything else alone may look bad, tackle the valve covers, STB, brackets, supports, whatever else you wanna paint to make it alll look nice. this was all done in my driveway btw, and im by no means an experienced painter!
nothing is more rewarding than to have someone ask you "Who painted that?" and you reply "I DID!"
