LED Gauge Cluster Lights
here is a pic of mines.. used 6 wledxhp. i thought i need 7. but i one of them was for the odometer.
here you see the bulb locations and how many i have. 98 z28 M6
i may be changing the led again.. as yall can see the 50-80mph area is slightly dimmer.. i may change to the 6 led version and the hvac go with the the 3led version. like fbodyrs96..
2 74-xHP3 Wedge Base LED bulb for the HVAC and 5-7 WLED-x5 LED Wide Angle LED in your choice of color..and if you do the head light switch you need 1 3mm NeoWedge Instrument led and you can get these at super bright leds .com....
