best HID projector housing or best way to put HIDs on camaros
now before the
begins along with the rice comments, im trying to find a good housing for a 99 z28 that will have a decent cutoff. let me see some different setups if you guys can. i also saw that some people are using the TSX projectors and what not. so let the pictures and hopefully the writeups begin
![Punch](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_punch.gif)
![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
Copy & Paste Moderator
Your best bet is to retrofit a true HID setup from an OEM into the stock Camaro housings.
TSX, RX330, S2K are some good low-beam-only projectors that should fit into the low beam area of the 1998-2002 Camaro. Of that list, TSX is probably the easiest to get and work with.
If you want a bi-xenon projector (high and low beam in one projector), FX & TL are a couple good choices as well. The FX should fit without a problem. The TL is a bit larger so I'm not sure. There are some other good choices as well, but they are larger and may or may not fit. For example, the 430 (or 460, I forget which is one of the two is bi-xenon) is a great bi-xenon projector, but its a bit large and may not fit.
Check out HID Planet's forms for more info on retrofits. I don't think I've seen any 1998-2002 Camaro specific ones though, but the site in general has plenty of info and is a great community.... kinda like this one. I'm on there with the same screen name as are a few other members from here.
Here are some threads/pages to look into:
zfastss's setup using TSX projectors mounted inside the stock housings:
http://home.comcast.net/~azafrin/04%...fit%20into.pdf
jvrss396's setup with Hella 90mm H9 projectors mounted inside the stock housings:
http://community.webshots.com/album/116863233uyEamc
General Discussion
https://ls1tech.com/forums/appearanc...-retrofit.html
General Discussion
so basically i guess im going to have to just make some. does anyone have any experience with the projector housings that are being made for our cars?
Here is the Lighting FAQ:
https://ls1tech.com/forums/appearanc...hting-faq.html
Here is a thread with the newer H1 version:
https://ls1tech.com/forums/appearanc...tmas-pics.html
Alternatively, you could buy one of the aftermarket Camaro projector housings and replace the halogen projector with a HID projector. I think there was a thread a while back where that was discussed, but I don't know what happened to it. If I remember correctly the space inside the aftermarket housings is tight. A HID projector might not fit. Only one way to know though. Someone has to try it.
