93-97 HID Headlights
my stock headlights just went out on my 93 z28. I have been looking around to find ways to put HID's on it. Does anyone have and suggestions on what to do?
Copy & Paste Moderator
Check out the Lighting FAQ:
https://ls1tech.com/forums/appearanc...hting-faq.html
Blackbirdws6's setup using Bi-Xenon FX projectors:
https://ls1tech.com/forums/appearanc...-write-up.html
You can get the Halogen Housings with higher wattage Halogen bulbs and an upgraded harness with relays. There are various ones around with various quality. Just avoid the "projector" ones. They are fake. They just stuck a crappy knock-off lens in front of the bulb and called it a projector. It's definitely not a projector and the output is crap.
Rally Lights has a set of Hella housings, but their listed prices are inaccurate. You'll have to call them. You can probably find them or similar ones on eBay and Amazon.
Susquehanna Motorsports - AKA - Rally Lights also sells on Amazon. The housings in question are listed from $35ea with no bulbs - to - $126ea with higher wattage bulbs and adapter cable (this sounds a bit expensive though, call to find out what is actually in that kit -- maybe its two housings and bulbs, the description is not clear).
I searched eBay for "H4666" and found some options, but they looked of questionable quality. They were cheaper, but they didn't look right, plus they came with blue bulbs which are crap.
