ASR relocation
Old Feb 9, 2009 | 08:29 PM
mook99ta's Avatar
Default ASR relocation
Is there any way to relocate the ASR Traction control box?
Old Feb 9, 2009 | 08:51 PM
Spd-Kilz's Avatar
Yes, there is. I'd post a link, but the search isn't working right now.
You locate it behind the PCM.
Edit:
https://ls1tech.com/forums/appearanc...tion-pics.html
Old Feb 10, 2009 | 12:33 AM
z_speedfreak's Avatar
nice why didnt I think of relocating it, I was just going to delete it.. GM shoulda put it their in the 1st place.
Old Feb 10, 2009 | 11:23 AM
PERFECT Z28's Avatar
Easy to do...really cleans up the bay.
Old Feb 10, 2009 | 12:56 PM
mook99ta's Avatar
So the majority of you guys just zip tied it up there or did you bolt it up
Old Feb 10, 2009 | 01:38 PM
either one will work...
ZIP-TIES...one the greatest creations EVER! lol
Old Feb 10, 2009 | 02:29 PM
SIC LSX's Avatar
did mine a while back and love it!
Old Feb 10, 2009 | 05:03 PM
Snuffles's Avatar
Mine is bolted up.
I'm not aware of anyone else who has bolted it up, though.
Many people just zip-tie it and some just throw it back there.
Old Feb 10, 2009 | 05:34 PM
nemss1's Avatar
im relocating mine to ebay
Old Feb 10, 2009 | 05:40 PM
mook99ta's Avatar
Doesn't it need to be secured for it to work properly
Old Feb 10, 2009 | 07:34 PM
Snuffles's Avatar
Nope.
I bolted mine so it didn't rattle around.
Especially since it's so close to the PCM.
Old Feb 10, 2009 | 07:58 PM
SIC LSX's Avatar
mine has been just laying back there for almost a year
Old Feb 10, 2009 | 08:43 PM
97camarozguy's Avatar
I did mine a few weeks ago and just did my buddies a couple nights ago. Its pretty easy and really cleans things up!
Old Feb 13, 2009 | 09:39 AM
mook99ta's Avatar
Originally Posted by Snuffles
Mine is bolted up.
How did you bolt it up there. Do you have any close up pictures?
Old Feb 13, 2009 | 04:58 PM
Snuffles's Avatar
mook99ta, I know you PM'd me but I'm going to post here so others can search this later.
Here are two pictures that show where and how I bolted the module to the cowl.
I center-punched where I wanted to drill.
Two drill bits were picked, one that fit my bolt and one that was larger than the socket I was using to tighten the bolt.
The larger bit was used to go through the upper cowl.
Once the large hole was drilled I used the smaller bit to through the SAME hole to drill into the lower portion of the cowl.
(See the picture if this description is confusing.)
And important note: you will not be able to drill with the hood completely closed and you will not be able to drill with the hood completely open.
Use a piece of wood (or something comparable) to prop the hood open, see the third picture.
Then use a skinny piece of wood between where your drilling and the hood.
This is just in case the drill bit doesn't bite and slips. You'll mess the wood up, not your hood.
Also, excuse the dirty car. It was December and it's my DD.
Old Feb 13, 2009 | 05:46 PM
Spd-Kilz's Avatar
That's probably the best place to put it.
Old Feb 13, 2009 | 06:16 PM
nemss1's Avatar
it cleans up the engine bay, reduces a lil weight and makes me money
