NEW LED Tail Lights done! All Superflux
#42
How come you used several resistors instead of one main resistor on the positive wire feed? Just wondering cause I may do this later on. Also what MCD leds did you use?
Is it just me or why does the lights seem to dim after appling the brakes?
It does look bad *** tho. Give you props.
#44
yep thats it
#46
I can help. That's just how wiring LED's works. Power in, then put the resistor onto the ground. You do Series / Parallel wiring because you can only power so many LED's off 12v-14v. Say your LED's are 3.0v a piece, 3.0v x 4 LED's = 12.0v. You won't have enough power to run any more LED's. So you only wire 3 up in Series and use a resistor to take up the remaining voltage.
Here's a link to help you figure out your wiring and resistor values: http://led.linear1.org/led.wiz
Hope that's not too confusing.
#48
subscribing.....
good work but why not make one big strip of LEDs all red and just seperate sections for brake lights, running lights, and blinkers? i dont believe amber is a required color in the back for turn signals as a lot of cars incorporate their brake lights as turn signals. i think itd look a lot nicer all little red LEDs do it Caddy style!
