Dashplates are now available!
Old Mar 25, 2002 | 10:39 AM
Mark IXZD 150's Avatar
Default Dashplates are now available!
Please read all the ordering info carefully.
SS and Z28 versions:
<img src="http://store5.yimg.com/I/afterthoughtsauto_1681_295605" alt="" />
PONTIACS:
<img src="http://store5.yimg.com/I/afterthoughtsauto_1681_840246" alt="" />
Go here to order:
http://www.afterthoughtsauto.com/cusdasplat.html
<small>[ March 25, 2002, 10:43 AM: Message edited by: Mark IXZD 150 ]</small>
Old Mar 25, 2002 | 03:41 PM
Xsta Z 28's Avatar
Default Re: Dashplates are now available!
Sweet! <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" />
Old Mar 25, 2002 | 06:17 PM
Steve1969LS1's Avatar
Ohhhhh... Ahhhhhhhh.. Wowwwwwwwwwww <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Gotsa order me one of them fancy plate thingies..
And as a director I appreciate that your moving them through an actual board sponsor <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Mar 25, 2002 | 06:56 PM
Raven's Avatar
Hello all,
here's a question:
I would like to order a HP specific plate for my car after I get it dyno'ed in a couple weeks (after some mods).
Now, should I have the HP number on the plate be the number the dyno shows (at the rear wheels), or should I convert it to HP at the flywheel? (I have an auto, so the RWHP should be 18-20 % less than the HP at the flywheel ~ I think~).
What do you guys think? - All opinions will be considered.
Thanks in advance,
-Bradster <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Old Mar 25, 2002 | 08:16 PM
Xsta Z 28's Avatar
I would calculate your loss factor and figure what your "Crank" horsepower is. And 20% is what I've been told.
There fore my SS with an A4 dynoed at 310 RWHP which means I supposedly have 372 HP. I'll gladly show that!
Old Mar 25, 2002 | 08:47 PM
Raven's Avatar
That's the direction I was leaning towards, XstaZ <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> I'll go with the flywheel numbers converted from the RWHP numbers <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" />
P.S.: Is the conversion factor the same for the Torque number as the HP number? Or is there any conversion number at all for torque at the flywheel as compared to torque at the rear wheels? <img border="0" title="" alt="[Roll Eyes]" src="images/icons/rolleyes.gif" />
<small>[ March 25, 2002, 08:50 PM: Message edited by: Raven99 ]</small>
Old Mar 25, 2002 | 09:10 PM
mjf454's Avatar
I like it, i am going on the dyno Wed for a retune.I want fwhp.Wouldnt 20% be to much? Seems as though it would be a fixed amount of power loss. Adding more hp at the wheels shouldnt make the drivetrain suck up more power, it should be the same loss no matter how much hp? <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old Mar 25, 2002 | 09:40 PM
I've heard A4 loses 20% and M6 loses 15%. I don't know how it works with torque though. Probabaly best to have it dynoed.
Old Mar 25, 2002 | 09:51 PM
Raven's Avatar
From what I understand about it (and I could be wrong about this), a typical HP loss for an automatic equipped car is 18-20% from the HP made at the flywheel. For Manual cars the HP loss is typically 15-18 % (I think). This would give you a formula that looks like this:
RWHP= Flywheel HP x .80 (for an automatic)
So from that formula, you take your RWHP reading from a dyno run and divide by .80 (for a 20% drivetrain loss if you have an auto) to get the HP made at the flywheel.
So if your car dyno'd 320 HP at the rear wheels, then the HP at the flywheel would be 320 divided by .80 = 400 HP . I could be way off about this, but that is how I understood it to work.
Again, anybody know of a conversion formula for TORQUE from the flywheel to the rear wheels (if there is one)? Or is it the same as the HP conversion factor? Is it depedent on stall speed / STR ratio of theTC ? <img border="0" title="" alt="[Roll Eyes]" src="images/icons/rolleyes.gif" />
-B
Old Mar 25, 2002 | 10:45 PM
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Raven99:
<strong>
-B</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Im not a math wiz but i think your formula to convert RWHP to FWHP is wrong.. If you made 400fwhp and had a 15% drive train loss then you would loose 15rwhp per every 100fwhp.. So you would loose 60hp (4 x 15) So 340rwhp would equate to 400fwhp.. Its late and I cant make sense of the needed formula.. for an M6 340 x 1.18 yields ~400 .. but that dosent make sense to me.. I DO KNOW that 340 rwhp is 400fwhp..
Math wizzes?
Torque is calculated the same way.. oh and the standard numbers everyone uses is 20% for an A4 and 15% for an M6.. although ive heard 18% for an A4 used quite often.. mostly due to the fact that modern automatic transmissions are more efficent these days..
Currently I would get a plate that says 391hp and 400tq -- I will probley get one that says 415hp and 410tq for when I get my cam <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
I like the results or your formula better though <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Mar 26, 2002 | 12:49 AM
adm408's Avatar
all <img border="0" alt="[hail]" title="" src="graemlins/gr_hail.gif" /> mark!
Old Mar 26, 2002 | 08:19 AM
Raven's Avatar
Dude, we're both right - I used the conversion factor for automatics (20%) in my example and you used the conversion feactor for manual trannys (15%). We just used two different ways to resolve the same equation. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
-B <img border="0" alt="[judgement]" title="" src="graemlins/gr_judge.gif" />
Old Mar 26, 2002 | 11:40 AM
<strong>Dude, we're both right - I used the conversion factor for automatics (20%) in my example and you used the conversion feactor for manual trannys (15%). We just used two different ways to resolve the same equation. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
-B <img border="0" alt="[judgement]" title="" src="graemlins/gr_judge.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">DOH!!! thats what happens when you try to do math late in the day.. lol.. so for M6 people its
rwhp / .85 = fwhp <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Mar 26, 2002 | 03:34 PM
Wicked Ls1's Avatar
So i guess that is just for cars with an aftermarket lid and catback? <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old Mar 26, 2002 | 03:52 PM
Xsta Z 28's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Wicked Ls1:
<strong>So i guess that is just for cars with an aftermarket lid and catback? <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">No, its for EVERYTHING!!! There is an easy order for the just the basic numbers, but down on the lower right hand corner you can order it with ANY numbers you like, just be honest.
So, "IF" your SS has 435 HP and 410 TQ you can get that, just fill out the right blanks.
Old Mar 26, 2002 | 04:21 PM
Trans Am WS6 420's Avatar
Does anyone have a picture in a Firebird? <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
- Matt
Old Mar 26, 2002 | 04:47 PM
Wicked Ls1's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Xsta Z 28:
<strong> </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Wicked Ls1:
So, "IF" your SS has 435 HP and 410 TQ you can get that, just fill out the right blanks.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Sweet! Let me finish up on some more mods and I'll be getting one!
Jason
Old Mar 27, 2002 | 08:35 AM
<strong>Sweet! Let me finish up on some more mods and I'll be getting one!
Jason</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Don't wait too long. It's likely to be a limited time offer.
Old Mar 27, 2002 | 11:19 AM
NataSS Inc's Avatar
I have a 99 and from the looks of where the plaque goes is right where the ASR button is, or will this fit there even with the ASR? I also think I am going to wait until the heads & cam go on the car and do a custom plate after dyno.
TERRY's Avatar
LOOKS REALLY NICE!!!!!!!
