Any one have instructions on how to keep both brights & headlights on?
if you have intructions or know how to let me know because I want to be able to keep both the brights and headlights turned on on my camaro, especially out here in west texas. Thanks
Re: Any one have instructions on how to keep both brights & headlights on?
you would have to install a relay on the high beam power wire and have the output of the relay go to the low beam power wire. your low beams will function normally and the high beams will be real bright!! <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" /> Good luck any ?s email me. Rich
You may also want to keep your fog lights on along with the high beams. I did this on my 94 Z28 and on my 00 T/A. Just find the light green wire going into the underhood fuse pannel where the fog light relay is. Cut it, and ground the end that goes into the relay. Tape off the end that goes into the wiring harness. Now you can have all 6 lights on when you are in high beam mode.
Good luck,
Good luck,
BE CAREFULL - If you run across an officer, especially DPS, you migt get a ticket if you have all six lights on at one time!
It's against the law in texas to run more than four driving lamps !
But i would think the cop would have to be pretty board!!!!!!
oops!!!!!!! So i can't spell <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by rich:
<strong>you would have to install a relay on the high beam power wire and have the output of the relay go to the low beam power wire. your low beams will function normally and the high beams will be real bright!! <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" /> Good luck any ?s email me. Rich</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Thanks Rich. I'm electronics dumb but if you don't mind me asking, what kind of relay do I need to get, and where would I find the high and low beam power wires? Thanks
As far as the fog lights...I don't have any <img border="0" title="" alt="[Sad]" src="gr_sad.gif" /> , I wish I did though.
it has nothing to do w/ relays. all you have to do is buy a splice lock (package of 10 is $2) and connect 2 wires under the steering column. it took me about 5 min total. theres directions on it somewhere, try posting on ls1.com, thats where i found it.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by LS1BlackZ28:
<strong>it has nothing to do w/ relays. all you have to do is buy a splice lock (package of 10 is $2) and connect 2 wires under the steering column. it took me about 5 min total. theres directions on it somewhere, try posting on ls1.com, thats where i found it.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">thanks and welcome to ls1tech
