Engine Cleaning
Old Oct 14, 2003 | 09:52 AM
KEVWS6SPEED's Avatar
Default -_-_-ENGINE CLEANING-_-_-
I would like to clean up everything under the hood. Im going to put it away for the winter so i got alot of time. Could you please fill me in on how what products to use and what products to stay away from and would love for it to shine like its brand new thanks you
kev
Old Oct 14, 2003 | 10:03 AM
Nine Ball's Avatar
LS1Tech Co-Founder
Default Re: -_-_-ENGINE CLEANING-_-_-
I just spray it down with some Simple Green, let it sit about 5 minutes, then hose it off. Power Washers work well also, just try your best to avoid anything electrical when spraying directly.
Old Oct 14, 2003 | 04:49 PM
simple green i never heard of it
should i like skrub or just put it on?
Old Oct 14, 2003 | 05:42 PM
felton316's Avatar
Its an automotive degreaser thats enviormentally friendly, which makes it really safe for engines. You shouldn't have to scrub after letting it sit, but sometimes I give it a follow-up wipe.
Old Oct 14, 2003 | 05:48 PM
thanks alot guys !!
Old Oct 14, 2003 | 05:59 PM
Ferocity02's Avatar
Just be really careful. You can screw up a lot of things by cleaning the motor. I trashed one of the idler pullies by getting water in it. Cover up the fuse boxes and PCM. And don't spray directly on wires, even if they are in wire loom.
Old Oct 14, 2003 | 09:44 PM
soundengineer's Avatar
and definately NO HIGH PRESSURE
keep everything down to the low pressure spot free rinse that you get at the car wash....with out squeezing the trigger....takes a little time...but its safer and smarter
Old Oct 14, 2003 | 11:19 PM
BIGBOS's Avatar
Simple Green can be found at any auto store..
Let it sit then rinse off, DEFIENTLY keep the water away from the electrials and pulleys...
Old Oct 15, 2003 | 12:28 AM
Ought1-Z28's Avatar
stay away from purple power, it corrodes aluminum!!!!
Old Oct 15, 2003 | 02:59 AM
LS1MONSTER's Avatar
Don't forget..never wash a hot engine!
Old Oct 15, 2003 | 10:55 AM
foff667's Avatar
LS1TECH Sponsor
ive used foamy engine bright...covered up electronics sprayed on lightly spray water to get it off...hard to get to the back of the motor though so only 3/4 is clean
lata
Bill
Old Oct 15, 2003 | 10:56 AM
foff667's Avatar
LS1TECH Sponsor
fyi you can see before and after pics on my website. My **** was brown before i got to it.
