How do you clean your engine bay
Old Mar 12, 2009 | 10:17 PM
SS LeadFoot's Avatar
Question How do you clean your engine bay
I was just wondering how you keep your engine/ engine bay so clean. I use zaino on the outside and that works GREAT! What should I use to clean the engine though and how should it be done. Thanks
Old Mar 12, 2009 | 11:48 PM
Screamin_99's Avatar
Cover electrical with Plastic bags. (major things only) Spray with a diluted Degreaser such as simple green or purple power 3 parts water to 1 part cleaner is advised. let stand.. old rag and wipe over everything while or once its done. rinse quickly. gently wash. rinse again. remove bags damp clean cloth to get near the electrical. use a interior spray such as NXT Cockpit and or a tire shine.. for the hoses/clamps and plastics. wax the paint.
Once you do it once and spend some time on it. it only makes doing it again very easy.
Scream,
Old Mar 12, 2009 | 11:59 PM
NHRAMAN's Avatar
From: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Toothbrush and 1" paint brush helps for hard to get to areas also...
Old Mar 13, 2009 | 01:35 AM
jsteele90's Avatar
i rinse it lightly then spray with simple green let it sit for a few minutes. then rinse. apply cd12 afterwards.
Old Mar 13, 2009 | 06:20 AM
jman0322's Avatar
X2 and it CD2 is the shiz!!!
Old Mar 13, 2009 | 07:58 AM
UTfan01SS's Avatar
I make it a habit to wipe my engine bay down with armor all and a rag each time I wash the car, usually once a week. I also use mothers aluminum polish on the heads, TB and any other aluminum I can get to. My engine stays spotless, even when I daily drive the car in the summer. It just takes some time and TLC to keep it clean. In this pic the engine bay wasn't as clean as it normally is as I just got back from driving seven hours from Ft. Bragg to Knoxville.
Old Mar 13, 2009 | 09:54 AM
mrhzk35404's Avatar
Scream,
Are the major things the computer and fuse block only?
Old Mar 13, 2009 | 09:59 AM
NebWS6's Avatar
wish they still sold it...
Old Mar 13, 2009 | 04:51 PM
Depends on how **** you are as to what you cover but yes those are the major things I would cover.
Old Mar 13, 2009 | 07:23 PM
ls2 bait's Avatar
just blow mine off with the air compressor every couple days. and since its all painted i just use the absorber and wipe it down.
Old Mar 13, 2009 | 07:35 PM
LS1-450's Avatar
I thought Simple Green was known to harm aluminum?
Old Mar 13, 2009 | 11:01 PM
LawmanSS's Avatar
From the "Hall of Fame" sticky up at the top of the section:
https://ls1tech.com/forums/appearanc...ngine-bay.html
Old Mar 15, 2009 | 07:25 PM
Thanks i will do this oncw the weather gets nice. Thanks for all the info and the link. Will post pics soon.
