The Spoiler Company issues continued... Need help guys
Hey guys, as some of you know. Last week I posted pictures of my SS spoiler that I got from thespoilercompany. The pictures showed the spoiler VERY tweaked. It fit horribly. So I contacted the company and they sent me a new, painted one. Got it today and out of the box everything looked to be in good shape. Paint was so-so but what can you expect for $50? I set it up on the deck lid and everything looked to be MUCH better than the previous time.... That is until I bolted it down. The four threaded holes on the outsides of the spoiler don't line up and it positions the spoiler towards the rear of the car opening up the gap on the two wings of the spoiler furthest forward (towards the front of the car). You can see this from the pictures... Ugh...
I'm not sure why everyone else is having awesome luck with these spoilers and I am having terrible luck. Anyways, I think I might be able to work with this one if I can somehow seal up the existing holes and drill and tap new ones. This should line the hood up where I want it to be.
So my question is, is there something I can use to fill/harden in the existing holes and make my own to mount the spoiler down?
Any help would be appreciated.
Here's the pictures..
![](http://i190.photobucket.com/albums/z315/98Redbird/IMG_1942.jpg)
![](http://i190.photobucket.com/albums/z315/98Redbird/IMG_1943.jpg)
![](http://i190.photobucket.com/albums/z315/98Redbird/IMG_1944.jpg)
![](http://i190.photobucket.com/albums/z315/98Redbird/IMG_1945.jpg)
![](http://i190.photobucket.com/albums/z315/98Redbird/IMG_1946.jpg)
![](http://i190.photobucket.com/albums/z315/98Redbird/IMG_1941.jpg)
![](http://i190.photobucket.com/albums/z315/98Redbird/IMG_1947.jpg)
Like I said before though, I can make this one work. I just need to make my own holes.
I recently got mine, and it seemed to line up right but I didn't try to bolt it down. The only complaint I have is it seems slightly short horizontally.
I wish I could help you more, but hopefully someone will chime in with some good info.
What's weird is when it's not bolted up or anything and you just set the spoiler into place it sits damn near perfect. I like the way it sits. It's just like the holes are drilled slightly off from where they need to be.
I'm just wanting to know if there is something that I can fill the existing holes with like an epoxy or something and then re-drill and tap new holes?
Thanks guys
I think it would still be easier to make holes in your hatch to match the spoiler than to make new threaded wholes in the spoiler. that area is covered with the plastics anyways so its not a big deal to drill a whole in it. It would be difficult to make new threaded wholes..
I agree with everyone else on just elongating the holes in the hatch.
You could use a two part epoxy to fill in the old holes, but it depends on what the spoiler is made out of to whether you can drill and tap it for a bolt. If it is fiberglass you would have to fill it in with epoxy or fiberglass resin and let it harden. Then you will have to use a riv-nut or something like that for a new location.
**** drilling your hatch man. Call the company back, send them the pics and make them send you a good one. Its not your fault that you paid good money and they've sent you two garbage spoilers.
I'm not at all angry here, I'm not even really frustrated, I just want something that fits just as well as OEM. That's all. I hacked into my last F car that I had and wish I had never done it. So I won't be doing it with this one.
Also, I found this comparo picture. This picture was taken from the this thread... https://ls1tech.com/forums/appearanc...t-not-oem.html
I am comparing the way that the lines square up as opposed to the one I just received... Not even close. You can tell that mine has a very rounded line which does not at all fit the body line of the hatch and his fit's perfect.
His:
![](http://i190.photobucket.com/albums/z315/98Redbird/Spoiler.jpg)
Mine:
It seems that the quality control of this company is pretty well fucked...
But that's just my experience thus far...
The more I look at this spoiler the more unacceptable it becomes. It's more than just the fact that the holes don't line up. That's not a huge deal to me. I could swing with that and still make it work. But you can't make up for fucked up lines like this one has.
any after market piece is the same in my opinion, there is always room for improvement, yours does not look bad at all , you dont have any groves or valleys in the spoiler like others mentioned with other companies, just line it up where you want it and dremel the hatch a little for clearance and use a nice washer, u should be good to go..those holes will never be seen even if you go back to oem,
What I cannot deal with is how shitty the lines look. Like I said before, if that's the way these are going to fit and line up I'll spend the extra $$ and go OEM. Easy as that. If you compare mine with the black Camaro it's not even close. His is exactly how it should look and line up and evidently it's from the same company... WTF?
Terrible quality control.
