painting calipers
Old Mar 30, 2009 | 01:00 PM
Nick_Rapitis's Avatar
Default painting calipers
will high temp engine enamel work or should i get actual caliper paint?
Old Mar 30, 2009 | 01:37 PM
RickyMartinZ28's Avatar
I used an actual caliper paint kit, the brush on works much better in my experience. It smooths out really well, and I followed mine up with some high temp clear.
Now my calipers look good, and are easier to clean than my wheels... just sprays right off...
Old Mar 30, 2009 | 02:11 PM
hitmanws6's Avatar
honestly i just bought a can of red paint at OSH for 2.99. scrubbed the calipers with soapy water and a wire brush and sprayed away. 2 light coats did it for me.
Old Mar 30, 2009 | 03:05 PM
greg_74's Avatar
Mine have two coats of VHT caliper paint on them. Just clean them real good before. I didn't clear mine, but a lot of guys do. Mine aren't too bad to keep clean, I just wipe them down when I wash the car.
Old Mar 30, 2009 | 03:24 PM
Spd-Kilz's Avatar
What you have will work fine.
I used both caliper paint, and high-temp engine paint. Both worked well.
Old Mar 30, 2009 | 08:16 PM
samson_420's Avatar
VHT lasts for a very long time. The only thing it ever does is chip from wheel removal, but nothing really helps that.
Old Mar 30, 2009 | 08:34 PM
Silver Metal's Avatar
I'm a fan of G2 caliper paint
Old Mar 30, 2009 | 09:14 PM
DriftR's Avatar
I used Folia Tec caliper paint. It's a high temp 2 part epoxy that you mix and brush on. Dries smooth with a very high gloss and comes in many different colors. It has been on my car for years and still looks the same as when I did it.
Old Mar 30, 2009 | 09:18 PM
02gtp4now's Avatar
i used some 98 cent walmart silver spray paint and mine still look good, but ive only put 7000 miles on it in a year and a half
Old Mar 30, 2009 | 09:24 PM
Yep thats the same a G2 paint a 2 step epoxy which is the way to go
Old Mar 30, 2009 | 10:19 PM
Danny2tek's Avatar
I went with the Duplicolor kit
Old Mar 30, 2009 | 11:20 PM
00MaroVSix's Avatar
i used hi temp engine paint and works perfect for me. when i wash my car i rub away what doesnt spray off and comes clean. i also used high temp clear over the top to make it shine even more
Old Mar 30, 2009 | 11:26 PM
lferdzl's Avatar
hi temp engine paint worked fine... just hit it with hi temp clear with a few caots and youre fine.
Old Mar 30, 2009 | 11:35 PM
lferdzl's Avatar
Old Mar 31, 2009 | 02:16 AM
masterz28's Avatar
I used caliper paint. I put seven coats on the front and five in the rear. Looks very smooth and glassy, and feels like rubber for some reason, meh.
