DETAIL: '06 Spice Red Metallic GTO
#41
LS1TECH Sponsor
The Menzerna IP or SIP is more aggressive than the TC Swirl Cutter in removing mild-moderate scratches from f-body clear coats using the orange or purple pad on the PC or FLEX.
#43
For most of the surface clean-ups, I have been using the gray or blue mild bars from Clay Magic. It has been very effective for removing contaminants easily without inflicting micro-marring.
#44
Originally Posted by After a quick rinse off to get rid of the loose dust, I started with our new citrus pre-wash concentrate in the Gilmour foam gun by spraying it on the surface and allowed it to set for about 5 minutes before washing. This will help to break down any remaining greasy dirt and road film.
[IMG
[IMG
http://i189.photobucket.com/albums/z110/tropi-care/detail_apr1_09/detail_apr1_09-07.jpg[/IMG]
First rinse after washing:
![](http://i189.photobucket.com/albums/z110/tropi-care/detail_apr1_09/detail_apr1_09-08.jpg)
#46
LS1TECH Sponsor
On darker colors, you may need to follow up with a finer abrasive/pad combo if there is any micro-marring or hazing inflicted from the stronger combo. Our Swirl Cutter with a white pad is one option. We will be adding the Menzerna 106FA later this week to the line up.
